Browse to the folder for a run that's in progress or has been completed.
Output files for a run can be monitored
at any time in the simulation. This is useful when, for example, a run has failed. The
individual run output files can be interrogated to try to determine the cause of the run
failure.
From the Design Explorer ribbon, Evaluate tool group, click the Run
Status satellite icon .
The
Run Status dialog opens.
After submitting a
simulation, this dialog will open automatically.
Right-click on a run that's in progress or completed and select
Browse Results.
The folder for the run in the output directory opens.
