Load Results
Visualize contours and animations for each run in the modeling window.
Do one of the following:
- From the Design Explorer ribbon, Evaluate tool group, click the
Results Explorer tool.
Figure 1.In the Results Explorer browser, click the Summary Table icon
Run Status satellite icon
After submitting a simulation, this dialog will open automatically.
Note: Using this dialog, individual runs can be contoured while the simulation is still in progress. Animations are not supported from the Evaluation Status dialog.
Right-click on a completed run and select Load Results.
The list of results types is populated dynamically based on the selected run.
- Select desired result type options.
- Click the Contour button or the Animation button.
