Create Explorations
Use the Create Explorations tool to create DOE or optimization explorations.
View new features for HyperWorks 2020.1.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
HyperMesh composites and tools.
An exploration is a multi-run simulation. Each exploration includes input design variables, and output responses. Explorations may also include goals, consisting of an objective and constraints. Optimization explorations require an objective.
Each type of exploration in HyperWorks serves a different purpose when investigating or improving a design.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters. This browser is only supported in OptiStruct and Radioss profiles.
Select which exploration to work with. Only one exploration can be active at a time.
Remove explorations from the model.
An input design variable is a system parameter that influences the system performance in the chosen output response. Typical design variables may be a part's thickness, shape, or material property. Ranges, with lower and upper bounds, are specified and the variable's value will vary within the exploration. The terms input, input design variable, and design variable are used interchangeably.
An output response is a measurement of system performances, such as mass, volume, displacement, stress, strain, or reaction forces.
Objectives are metrics to be minimized or maximized in an optimization exploration. Minimizing mass to find a lightweight design is a common example.
Constraints need to be satisfied for an optimization to be acceptable. Constraints may also be associated with a DOE. While not used in the evaluation of the DOE, constraints can be useful while visualizing DOE results. Limits on displacement or stress are common examples.
Use the Evaluate tools to run the exploration and review reports.
Examples show how to use the design explorer.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use marine tools to create a stiffener mesh.
ON THIS PAGE
Option | Description |
DOE | A DOE is a series of tests in which purposeful changes are made to the input variables to investigate their effect upon the output responses and to get an understanding of the global behavior of a design problem. By running a DOE, you can determine which factors are most influential on an output response. |
Optimization | An Optimization is a mathematical procedure used to determine the best design for a set of given constraints, by changing the input variables in an automatic manner. |
ON THIS PAGE
