Connector Import
Learn about importing connector files.
.xml
file that contains the following
headline:<xmcf xmlns:xs="http/www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http:
<version>3.0.0</version>
<data>2015-12-14</date>
- 0D: Spotweld, bolt, screw, gumdrop, clinch, rivet (blind, self-piercing, solid, swop), robscan, contact_list, threaded connection, heat stake, clip, nail
- 1D: Sequence connection 0D (spotweld, gumdrop), seamweld (butt_joint, corner weld, edge weld, i_weld, overlap weld, y-joint, k-joint, cruciform joint, flared joint), adhesive-line, hemming, contact list
- 2D: Adhesive face
- Custom attributes are managed.
- Appdata is not managed.
Connector Import Options
Options used when importing connector files.
- Overwrite
- ID Offset
- Define Offset
- Set offset to Zero
- Set offset to Max Value
- Set offset Value
- Offset By
- Use name to identify part link
- Import from common format
