H3D Export Options
Options used when exporting an H3D binary file.
General
File type
Select the file type to be exported.
FE only
Write FE data only.
Geometry only
Write geometry (STL) data only.
FE and Geometry
Write both geometry (STL) and FE data.
Write titles as notes
Write HyperWorks titles as HyperView notes.
Warning messages
Overwrite existing file
Display warning message upon overwriting an existing file.
Write to file
Results
For supported entities and result contours, this writes the displayed results to the H3D file. If no supported result contour is displayed, this option is ignored.
