Import Files
Import an existing file to the current session.
Importing any type of file into HyperWorks essentially means that the selected file is appended to any file currently open. It does not overwrite/replace the existing file. Therefore, you can use the Import option to open two (or more) files into one window.
Do one of the following:
- From the menu bar, select .
- Press Ctrl + I.
- In the Import File dialog, navigate to your working directory and select the file to import.
- Define any options in the Import Options dialog then click Import.
HyperWorks loads model files and solver input files with the solver interface they were saved in.
