Custom Import Options
Options used when importing data via a custom import reader.
Using the Custom option, you can import FE models for custom FE input translators created by customers for any internal or proprietary solver.
General
- Template
- Click and select the appropriate reader.
- Show import errors
- Display errors received during import process.
- Read ID rules
- Import ID management rules defined in the ID Manager.Restriction: Available when Include Files is set to Preserve
Include Files
- Import file as an include
- Import file as an include file
- Import behavior
- Select the appropriate import behavior.
- Merge
- Import the contents from all include files into the HyperMesh model, but do not maintain their references. When exporting, all entities are written into the master file.
- Preserve
- Preserve data in individual include files along with their references in the master model. Review the contents of individual include files in the Include browser. When exporting, entities are written into the corresponding include files along with their references in the master file.
- Skip
- Do not import data in the include file into HyperMesh. Include references are maintained and written out to the master model during export.
Display
- Select
- Choose which entities to display.Tip: This option can help improve the performance for FE input models containing large numbers of entities.
- All
- Display all entities in the selected file.
- Custom
- Select entities to display from the selected file.
- None
- Display none of the entities in the selected file.
ID Offsets
- Overwrite existing ID's
- Adjust offset settings.
- Offset by
- Select an offset method.
- None
- Entities are not offset.
- Custom
- Specify values to offset each entity.
- Set all IDs to MAX
- Set all entities to their maximum offset value.
- Set all IDs to ZERO
- Set the offset value of all entities to zero.
