Solver Deck Export
Export solver input files.
HyperWorks uses templates to create the analysis input decks for finite element solvers. You can modify the existing templates to support a desired feature or create a new template to support another analysis code. HyperWorks templates can be used to create model summaries and perform some analysis calculations. You can also use the templates to perform complex editing or data manipulation tasks.
The Media (*.bif
) is also supported for nodes,
elements (mass, beam, tria3, quad4, tetra4, tetra10, penta6, penta15, hexa8,
hexa20), and sets (nodes, elements) in the LS-DYNA user profile.
