Collectors Menu
Aerospace offers the following functions in the Collectors menu:
Table 1.
Assemblies Create and modify assemblies, which are collections of component and multibody collectors or other assemblies.
Components Create and update components.
Load Collectors Load collectors contain the loads applied to entities, such as pressures, fluxes or forces.
Vector Collectors Vector collectors contain vectors which can then be used to define loads or transformations.
System Collectors System collectors contain coordinate systems, which can then be applied to different components of a model.
Beam Section Collectors BeamSection Collectors contain beam section data.
Multibodies Multibodies are jointed bodies made up of multiple parts and are often used to simulate crash test dummies and similar objects during crash analysis.
Organize Reorganize your database by copying or moving data (entities) among collectors or includes.
Rename Change the name of a specific collector or to rename types of collectors to their respective ID with an optional prefix.
Renumber Renumber entities.
Reorder Change the order of named entities in database.
Color Change the color attributes of a collector
