Create Design Points
On each design point set, you can access the Auto DDP option available in the
context menu. Auto DDP provides a set of options to
create design points.
- A selector to reduce detection area
- Options for pattern detection
- Options for structural property to create and assign (if any)
Click OK.
An algorithm detects patterns and generates a collection of design points inside the parent design point set. Depending on the options, it also creates and/or assigns structural properties. Auto DDP always creates new design points inside a design point set, no matter what already exist in the database. This allows you to have multiple design points at the same location, but with different structural properties.
