Create Design Point Sets
The certification process is managed from the Certification Browser.
  1. From the menu bar, click Aerospace > Certification > Certify, if the Certification Browser is not already open.
  2. Select the desired configuration of design point set to create.
  3. Create one or several design point sets by clicking the + icon.
    Note:
    Duplicate DDP Set
    Results in another design point set created with reference to the exact same design points as in the source design point set (same design point IDs, no duplication). Methods assigned to the source design point set are not copied.
