Implement RBE2 Connection with Assigned DOFs
Implement a special RBE2 connection with assigned DOFs.
View new features for HyperWorks 2020.1.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
HyperMesh composites and tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Create an assembly structure from a .csv file definition.
Create and review pressure loads on 1D elements that are fully or partially loaded.
It is convenient to apply aerospace loads and concentrated mass that is predefined at specific node ID’s from an Excel file. This requires carefully numbering nodes with specific ID’s, which is a standard practice in aerospace.
Line loads allow total loads (forces and moments) to be applied in a distributed manner on nodes even though the load is applied on geometry lines or set of nodes forming ordered edges.
Connect two dissimilar meshes using displacement constraint elements.
Translate, scale, reflect or rotate elements with multiple numbers of copies, including properties and loads, attached to them.
Converts the pressure load to be applied on shell elements to equivalent forces on the corner nodes of the selected shell elements.
Map thermal loads from one model to another.
Framework to plug certification methods inside HyperWorks to assess margin of safety from the model and result information.
Use marine tools to create a stiffener mesh.
ON THIS PAGE
ON THIS PAGE
