PCOMP From CSV
PCOMP from CSV generates HyperMesh composite properties from data defined in a .csv file.
The required file format is shown in the table below. Layers of a property must share a single material ID and thickness. If this is not your use case, refer to Data I/O Spreadsheets for other options.
From the menu bar, click Aerospace > Composites > PCOMP from CSV. In the Import file field, browse to the appropriate file and then click Create.
Table 1. File Format
PCOMP ID Material ID Thickness Orientation
1 1 0.01 -45 0 45 90 90 45 0 -45
2 1 0.01 0 90 0 90
11 5 0.02 30 0 30
