Perform Additional Operations on Data-Interactive Mode
The MinMax/Ranking/Envelope tool is an extension of the Results Query tool, and allows you to perform additional operations on data and get dedicated reporting.
View new features for HyperWorks 2020.1.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
HyperMesh composites and tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Create an assembly structure from a .csv file definition.
The results post-processing workflow is now embedded in HyperMesh, and you can seamlessly process solver native results in HyperMesh. The File Loader is used to generate the new results entity.
The File Loader allows you to import results from native load cases, in the HyperMesh data base, as well as via Load Combination file, to create derived load cases in the form of linear super-position and/or envelope. Use the Derived Load cases tool for the creation of these derived load cases.
Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
Enables exploring the element force and moment results (internal loads) from solver result files (grid point forces) for further component sizing/optimization tasks and also for component certification/margin calculation.
Calculate free-body forces, moments, displacements and rotation.
In Nastran, the F06 file contains information related either to the diagnostic of the model, analysis check up and results. This tool enables you to parse a defined number of information blocks and store them as a HyperMesh table entity with a given name.
Use this tool to evaluate for the selected elements the average value of the selected result type.
Framework to plug certification methods inside HyperWorks to assess margin of safety from the model and result information.
Use marine tools to create a stiffener mesh.
