Set Properties of a Selected Set
Select a set.
The properties display.
Name
The name of the selected set.
ID
The ID of the selected set.
Card Image
This property is optional. Defines the card for the set.
Entity IDs
Available if None has been defined as Card Image, and non-ordered or ordered as Set Type. Select what nodes and elements will belong to the set. If an element set has been selected, the free-body displacement will use all nodes belonging to the selected elements.
