Ale Reference System Curve
Ale Reference System Curve entities defines a motion and/or a deformation prescribed for a geometric entity, where a geometric entity may be any part, part set, node set, or segment set.
The motion or deformation is completely defined by the 12 parameters & these are defined in terms of 12 load curves. This command is required only when PRTYPE = 3 in the *ALE_REFERENCE_SYSTEM_GROUP command
LS-DYNA Cards
Card | Description |
*ALE_REFERENCE_SYSTEM_CURVE | Motion and/or a deformation prescribed for a geometric entity, where a geometric entity may be any part, part set, node set, or segment set. |
