Elements
Elements are FE idealizations for a portion of a physical part.
Every element must be organized into one component, and therefore are mutually exclusive to a component.
Element Configurations
Each element has an associated element configuration. An element configuration tells HyperWorks how to draw, store, and work with the element.
Bar Elements
1D elements created in a space between two or three nodes of a model where beam properties are desired.
The nodes are related to each other based on the properties of the bar or beam element connecting them. Properties associated with bar elements include vector orientation, offset vectors that end at A and B, or at A, B, and C, and pin flags to tell it what degree of freedom should carry through the beam.
Bar elements are displayed as a line between two nodes with BAR2 or BAR3 written at the centroid of the element.
Bar2
Configuration 60 - 1D (1st order) elements with 2 nodes used to model axial, bending, and torsion behavior. Bar2 elements have a property reference, an orientation vector, offset vectors and ends A and B, and pin flags at ends A and B.
Bar3
Configuration 63 - 1D (2nd order) elements with 3 nodes used to model axial, bending, and torsion behavior. Bar3 elements have a property reference, an orientation vector, offset vectors and ends A and B, and pin flags at ends A and B.
Gap Elements
Configuration 70 - 1D elements created in a space between two nodes, or between a node and an element, of a model where contact may occur.
Create a gap element when you want to impose a nonlinear constraint on a model; this constraint will limit the amount of movement possible during analysis.
Gap elements have a property reference and an orientation vector.
Gap elements are displayed as a line between two nodes with GAP written at the centroid of the element.
Gap elements can translate to CGAP or CGAPG elements in OptiStruct, CGAP element in Nastran or *GAP option in Abaqus.
Hex Elements
3D hexahedra elements.
Hex8
Configuration 208 - 3D (1st order) hexahedra elements with 8 nodes.
Hex20
Configuration 220 - 3D (2nd order) hexahedra elements with 20 nodes.
Figure 2. Element Configuration 220, 20-Noded Hexa
Joint Elements
Configuration 22 - 1D elements with 2, 4, or 6 nodes which have a property and orientation systems or nodes.
Joint element is a definition of a connection between two rigid bodies. Joint elements store a property and orientation information.
Joint elements are displayed with lines between the appropriate nodes and the letter J between nodes 1 and 3 of the element.
Only certain types of elements can be used to create joint elements. The type of the element controls the number of nodes used in the element and the permissible orientations of the element.
Table 1. Types of Joint Elements
Type Type Name Number of Nodes Orientation Solver Interface
1 Spherical joint 2
  • None
  • Systems
  • Nodes
  • LS-DYNA
  • PAM-CRASH
2 Revolute joint 4
  • None
  • Systems
LS-DYNA
3 Cylindrical joint 4
  • None
  • Systems
LS-DYNA
4 Planar joint 4
  • None
  • Systems
LS-DYNA
5 Universal joint 4
  • None
  • Systems
LS-DYNA
6 Translational joint 6
  • None
  • Systems
LS-DYNA
7 Locking joint 6
  • None
  • Systems
LS-DYNA
8 Ball joint 2 None OptiStruct
9 Fixed joint 2 None OptiStruct
10 Revolute joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
11 Translational1 joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
12 Cylindercal 1 joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
13 Universal joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
14 Constant_velocity joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
15 Planar joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
16 Inline joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
17 Perpendicular joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
18 Parallel axes joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
19 Inplane joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
20 Orient joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
21 Point_to_curve joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
22 Curve_to_curve joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
23 Point_to_deformable_curve joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
24 Point_to_deformable_surface joint 2
  • Node
  • Vector
  • Coordinates
OptiStruct
25 Translational_2N joint 2
  • None
  • Systems
PAM-CRASH
26 Revolute_2N joint 2
  • None
  • Systems
PAM-CRASH
27 Cylindrical_2N joint 2
  • None
  • Systems
PAM-CRASH
28 Universal_2N joint 2
  • None
  • Systems
PAM-CRASH
29 Flexion-Torsion joint 2
  • None
  • Systems
PAM-CRASH
30 Planar_2N joint 2
  • None
  • Systems
PAM-CRASH
31 General joint 2
  • None
  • Systems
PAM-CRASH
32 Bracket joint 2
  • None
  • Systems
PAM-CRASH
33 Free joint 2
  • None
  • Systems
PAM-CRASH
Mass Elements
Configuration 1 - 0D elements with a single node that allow you to assign concentrated mass to the model in order to represent a physical part that may not be modeled with another FE idealization.
Mass elements are displayed as a dot with the letter M written at the centroid of the element.
Master Elements
Master interface elements.
Master3
Configuration 123 - Master interface elements with 3 nodes. (Must be Type 1).
Master4
Configuration 124 - Master4 elements are master interface elements with 4 nodes. (Must be Type 1).
Penta Elements
3D triangular prism pentahedra elements.
Penta6
Configuration 206 - 3D (1st order) triangular prism pentahedra elements with 6 nodes.
Figure 3. Element Configuration 206, 6-Noded Penta
Penta15
Configuration 215 - 3D (2nd order) triangular prism pentahedra elements with 15 nodes.
Figure 4. Element Configuration 215, 15-Noded Penta
Plot Elements
Configuration 2 - 1D elements with 2 nodes used for display purposes.
Plot elements are displayed as a line between two nodes.
Pyramid Elements
3D pyramid pentahedra elements.
Pyramid5
Configuration 205 - 3D (1st order) pyramid pentahedra elements with 5 nodes.
Figure 5. Element Configuration 205, 5-Noded Pyramid
Pyramid13
Configuration 213 - 3D (2nd order) pyramid pentahedra elements with 5 nodes.
Figure 6. Element Configuration 213, 13-Noded Pyramid
Quad Elements
2D quadrilateral elements.
Types of pyramid elements include:
Quad4
Configuration 104 - 2D (1st order) quadrilateral elements with 4 nodes.
Figure 7. Element Configuration 104, 4-Noded Quad
Quad8
Configuration 108 - 2D (2nd order) quadrilateral elements with 8 nodes.
Figure 8. Element Configuration 108, 8-Noded Quad
RBE3 Elements
Configuration 56 - Rigid elements with one dependent node and variable independent nodes typically used to define the motion at the dependent node as a weighted average of the motions at the independent nodes.
Both the dependent node and independent nodes contain a coefficient (weighting factor) and user-defined degrees of freedom. The dependent degrees of freedom and weighting factors can be specified or automatically calculated based on the geometry.
RBE3 elements are displayed as lines between the dependent node and the independent node(s) with RBE3 displayed at the dependent node of the element.
RBE3’s are typically used to distribute loads applied on the dependent node amongst the selected independent nodes.
Note: The dependent node cannot be directly constrained, as this would lead to a double-dependency for that node.
Rigid Elements
Configuration 5 - Rigid 1D elements with 2 nodes used to model rigid connections.
Rigid elements are displayed as a line between two nodes with the letter R written at the centroid of the element.
Rigids can translate to RBE2 in Nastran or *MPC in Abaqus.
Configuration 55 - Rigid elements with one independent node and variable dependent nodes typically used to model rigid bodies.
Rigidlink elements have user-defined degrees of freedom which apply to all dependent nodes.
Rigidlink elements can be created with dependent nodes attached to an element as a SET. If a rigid link with a dependent node set is deleted, the associated node set is also deleted. If the dependent node set is deleted, the connected rigid link element is also deleted. Dependent node sets are automatically created when rigid link elements are created. A node set can be connected as a set of dependent nodes to a rigid link element independent node.
Note: Two-node rigids with a dependent node set attached are always created as rigid link elements
Rigidlink elements are displayed as lines between the independent node and the dependent node(s) with RL displayed at the independent node of the element.
Rod Elements
Configuration 61 - 1D elements with 2 nodes used to model axial behavior only.
The two nodes are related to each other based on the properties of the rod element connecting them. Rod elements have property pointers.
Rod elements are displayed as a line between two nodes with ROD written at the centroid of the element.
Rods can translate to CTUBES in Nastran or a C1D2 element in Abaqus.
Slave Elements
Slave interface elements.
Slave1
Configuration 135 - Slave interface elements with 1 node. (Must be Type 1).
Slave3
Configuration 133 - Slave interface elements with 3 node. (Must be Type 1).
Slave4
Configuration 134 - Slave interface elements with 1 node. (Must be Type 1).
Spring Elements
Configuration 21 - 1D elements used to model spring connections.
Spring elements have user-defined degrees of freedom, an orientation vector, and a property reference.
Spring elements are displayed as a line between two nodes with the letter K written at the centroid of the element.
Spring
1D elements with 2 nodes used to model spring connections.
Spring2N
Spring3N
1D elements with 3 nodes used to model spring connections.
The third node serves as the direction node.
Spring4N
1D elements with 4 nodes used to model spring connections.
This type of element will mostly be considered as joints, based on the property it is assigned.
Springs can translate to CELAS2 in Nastran or *SPRING in Abaqus.
Tetra Elements
3D tetrahedra elements.
Tetra4
Configuration 204 - 3D (1st order) tetrahedra elements with 4 nodes.
Figure 9. Element Configuration 204, 4-Noded Tetra
Tetra10
Configuration 210 - 3D (2nd order) tetrahedra elements with 10 nodes.
Figure 10. Element Configuration 210, 10-Noded Tetra
Tria Elements
2D triangular elements.
Tria3
Configuration 103 - 2D (1st order) triangular elements with 3 nodes.
Figure 11. Element Configuration 103, 3-Noded Tria
Tria6
Configuration 106 - 2D (2nd order) triangular elements with 6 nodes.
Figure 12. Element Configuration 106, 6-Noded Tria
Weld Elements
Configuration 3 - Rigid 1D elements with 2 nodes used to model welded connections.
Weld elements are displayed as a line between two nodes with the letter W written at the centroid of the element.
Xelems
1D multi-strand elements.
Supported Solver Cards
Solver cards supported for elements.
Abaqus Cards
Card Supported Element Configurations Description
*COUPLING Rigid/RBE3 Define a surface-based coupling constraint where the *SURFACE card points to elements.
Note: The *COUPLING is also supported as rigid elements (COUP_KIN) and RBE3 (COUP_DIS) when *SURFACE points to nodes.
*ELEMENT
  • Bar2
  • Bar3
  • Gap (Standard 2D/3D)
  • Hex20 (Standard 3D)
  • Hex8 (Standard 3D/Explicit)
  • Mass
  • Penta15 (Standard 3D)
  • Penta6 (Standard 3D/Explicit)
  • Pyramid13 (Standard 3D)
  • Pyramid5 (Standard 3D/Explicit)
  • Quad4
  • Quad8 (Standard 2D/3D)
  • RBE3
  • Rigid
  • Rod
  • Spring
  • Tetra10 (Standard 3D/Explicit)
  • Tetra4 (Standard 3D/Explicit)
  • Tria3
  • Tria6 (Standard 2D/3D)
Defines elements by giving their nodes.
*ELGEN   Generates elements incrementally.
These cards are resolved to individual entities on import and are written back on export the same way.
Note: Standard 2D only.
*MPC Rigid Defines multi-point constraints.
*RELEASE
  • Bar2
  • Bar3
Releases rotational degrees of freedom at one or both ends of a beam element.
For 2D problems, only dof6 (M1) is active.
Add a *RELEASE card to this element by clicking pins a = and pins b = and type in the HyperWorks dof code for the Abaqus release combination code you want.
HyperWorks dof Code
Abaqus Release Combination Code
4
T
5
M2
45
M2-T
6
M1
46
M1-T
56
M1-M2
456
ALLM
AC1D2 Bar2 2-node acoustic link
AC1D3 Bar3 3-node acoustic link
AC2D3 Tria3 3-node linear 2-D acoustic triangle
AC2D4 Quad4 4-node linear 2-D acoustic quadrilateral
AC2D6 Tria6 6-node quadratic 2-D acoustic triangular prism
AC2D8 Quad8 8-node quadratic 2-D acoustic quadrilateral
AC3D10 Tetra10 10-node quadratic acoustic tetrahedron
AC3D15
  • Pyramid13
  • Penta15
15-node quadratic acoustic triangular prism
AC3D20
  • Pyramid13
  • Hex20
20-node quadratic acoustic brick
AC3D4 Tetra4 4-node linear acoustic tetrahedron
AC3D6 Penta6 6-node linear acoustic triangular prism
AC3D8 Hex8 8-node linear acoustic brick
AC3D8R Hex8
ACAX3 Tria3 3-node linear axisymmetric acoustic triangle
ACAX4 Quad4 4-node linear axisymmetric acoustic quadrilateral
ACAX6 Tria6 6-node quadratic axisymmetric acoustic triangle
ACAX8 Quad8 8-node quadratic axisymmetric acoustic quadrilateral
ACIN3D3 Tria3 3-node linear 3D acoustic infinite element
ACIN3D4 Quad4 4-node linear 3D acoustic infinite element
ACIN3D6 Tria6 6-node quadratic 3D acoustic infinite element
ACIN3D8 Quad8 8-node quadratic 3D acoustic infinite element
B21 Bar2 2-node linear beam in a plane
B21H Bar2 2-node linear beam in a plane, hybrid formulation
B22 Bar3 3-node quadratic beam in a plane
B22H Bar3 3-node quadratic beam in a plane, hybrid formulation
B23 Bar2 2-node cubic beam in a plane
B23H Bar2 2-node cubic beam in a plane, hybrid formulation
B31 Bar2 2-node linear beam
B31H Bar2 2-node linear beam, hybrid formulation
B31OS Bar2 2-node linear open-section beam
B31OSH Bar2 2-node linear open-section beam, hybrid formulation
B32 Bar3 3-node quadratic beam in space
B32H Bar3 3-node quadratic beam, hybrid formulation
B32OS Bar3 3-node quadratic open-section beam
B32OSH Bar3 3-node quadratic open-section beam, hybrid formulation
B33 Bar2 2-node cubic beam
B33H Bar2 2-node cubic beam, hybrid formulation
BEAM Rigid
C3D10 Tetra10 10-node quadratic tetrahedron
C3D10E Tetra10 10-node quadratic piezoelectric tetrahedron
C3D10H Tetra10 10-node quadratic tetrahedron, hybrid, constant pressure
C3D10HS Tetra10
C3D10I Tetra10 10-node general-purpose quadratic tetrahedron, improved surface stress visualization
C3D10M Tetra10 10-node modified tetrahedron, hourglass control
C3D10MH Tetra10 10-node modified quadratic tetrahedron, hybrid, linear pressure, hourglass control
C3D10MP Tetra10 10-node modified displacement and pore pressure tetrahedron, hourglass control
C3D10MPH Tetra10 10-node modified displacement and pore pressure tetrahedron, hybrid, linear pressure, hourglass control
C3D10MT Tetra10 10-node thermally coupled modified quadratic tetrahedron, hourglass control
C3D10S
C3D15
  • Pyramid13
  • Penta15
15-node quadratic triangular prism
C3D15E
  • Pyramid13
  • Penta15
15-node quadratic piezoelectric triangular prism
C3D15H
  • Pyramid13
  • Penta15
15-node quadratic triangular prism, hybrid, linear pressure
C3D20
  • Pyramid13
  • Penta15
  • Hex20
20-node quadratic brick
C3D20E
  • Pyramid13
  • Hex20
20-node quadratic piezoelectric brick
C3D20H
  • Pyramid13
  • Hex20
20-node quadratic brick, hybrid, linear pressure
C3D20HT
  • Pyramid13
  • Hex20
20-node thermally coupled brick, triquadratic displacement, trilinear temperature, hybrid, linear pressure
C3D20PH Hex20 20-node brick, triquadratic displacement, trilinear pore pressure, hybrid, linear pressure
C3D20R
  • Pyramid13
  • Penta15
  • Hex20
20-node quadratic brick, reduced integration
C3D20RE
  • Pyramid13
  • Hex20
20-node quadratic piezoelectric brick, reduced integration
C3D20RH
  • Pyramid13
  • Hex20
20-node quadratic brick, hybrid, linear pressure, reduced integration
C3D20RHT
  • Pyramid13
  • Hex20
20-node thermally coupled brick, triquadratic displacement, trilinear temperature, hybrid, linear pressure, reduced integration
C3D20RP Hex20 20-node brick, triquadratic displacement, trilinear pore pressure, reduced integration
C3D20RPH Hex20 20-node brick, triquadratic displacement, trilinear pore pressure, hybrid, linear pressure, reduced integration
C3D20RT
  • Pyramid13
  • Hex20
20-node thermally coupled brick, triquadratic displacement, trilinear temperature, reduced integration
C3D20T
  • Pyramid13
  • Hex20
C3D30P Hex20 20-node brick, triquadratic displacement, trilinear pore pressure
C3D4 Tetra4 4-node linear tetrahedron
C3D4E Tetra4 4-node linear piezoelectric tetrahedron
C3D4H Tetra4 4-node linear tetrahedron, hybrid, linear pressure
C3D4P Tetra4
C3D4T Tetra4 4-node thermally coupled tetrahedron, linear displacement and temperature
C3D6
  • Pyramid5
  • Penta6
6-node linear triangular prism
C3D6E
  • Pyramid5
  • Penta6
6-node linear piezoelectric triangular prism
C3D6H
  • Pyramid5
  • Penta6
6-node linear triangular prism, hybrid, constant pressure
C3D6P Penta6
C3D6T Penta6 6-node thermally coupled triangular prism, linear displacement and temperature
C3D8
  • Pyramid5
  • Penta6
  • Hex8
8-node linear brick
C3D8E
  • Pyramid5
  • Hex8
8-node linear piezoelectric brick
C3D8H
  • Pyramid5
  • Hex8
8-node linear brick, hybrid, constant pressure
C3D8HS Hex8
C3D8HT
  • Pyramid5
  • Hex8
8-node thermally coupled brick, trilinear displacement and temperature, hybrid, constant pressure
C3D8I
  • Pyramid5
  • Hex8
8-node linear brick, incompatible modes
C3D8IH
  • Pyramid5
  • Hex8
8-node linear brick, hybrid, linear pressure, incompatible modes
C3D8P Hex8 8-node brick, trilinear displacement, trilinear pore pressure
C3D8PH Hex8 8-node brick, trilinear displacement, trilinear pore pressure, hybrid, constant pressure
C3D8R
  • Pyramid5
  • Penta6
  • Hex8
8-node linear brick, reduced integration, hourglass control
C3D8RH
  • Pyramid5
  • Hex8
8-node linear brick, hybrid, constant pressure, reduced integration, hourglass control
C3D8RHT
  • Pyramid5
  • Hex8
8-node thermally coupled brick, trilinear displacement and temperature, reduced integration, hourglass control, hybrid, constant pressure
C3D8RHT Pyramid5 8-node thermally coupled brick, trilinear displacement and temperature, reduced integration, hourglass control, hybrid, constant pressure
C3D8RP Hex8 8-node brick, trilinear displacement, trilinear pore pressure, reduced integration
C3D8RPH Hex8 8-node brick, trilinear displacement, trilinear pore pressure, reduced integration, hybrid, constant pressure
C3D8RT
  • Pyramid5
  • Hex8
C3D8S Hex8
C3D8T
  • Pyramid5
  • Hex8
CAX3 Tria3 3-node linear axisymmetric triangle
CAX3E Tria3 3-node linear axisymmetric piezoelectric triangle
CAX3H Tria3 3-node linear axisymmetric triangle, hybrid, constant pressure
CAX3T Tria3 3-node axisymmetric thermally coupled triangle, linear displacement and temperature
CAX4 Quad4 4-node bilinear axisymmetric quadrilateral
CAX4E Quad4 4-node bilinear axisymmetric piezoelectric quadrilateral
CAX4H Quad4 4-node bilinear axisymmetric quadrilateral, hybrid, constant pressure
CAX4HT Quad4 4-node axisymmetric thermally coupled quadrilateral, bilinear displacement and temperature, hybrid, constant pressure
CAX4I Quad4 4-node bilinear axisymmetric quadrilateral, incompatible modes
CAX4IH Quad4 4-node bilinear axisymmetric quadrilateral, hybrid, linear pressure, incompatible modes
CAX4R
  • Tria3
  • Quad4
4-node bilinear axisymmetric quadrilateral, reduced integration, hourglass control
CAX4RH Quad4 4-node bilinear axisymmetric quadrilateral, hybrid, constant pressure, reduced integration, hourglass control
CAX4T Quad4 4-node axisymmetric thermally coupled quadrilateral, bilinear displacement and temperature
CAX6 Tria6 6-node quadratic axisymmetric triangle
CAX6H Tria6 6-node quadratic axisymmetric triangle, hybrid, linear pressure
CAX6M Tria6 6-node modified axisymmetric triangle, hourglass control
CAX6MH Tria6 6-node modified quadratic axisymmetric triangle, hybrid, linear pressure, hourglass control
CAX8 Quad8 8-node biquadratic axisymmetric quadrilateral
CAX8H Quad8 8-node biquadratic axisymmetric quadrilateral, hybrid, linear pressure
CAX8HT Quad8 8-node axisymmetric thermally coupled quadrilateral, biquadratic displacement, bilinear temperature, hybrid, linear pressure
CAX8R Quad8 8-node biquadratic axisymmetric quadrilateral, reduced integration
CAX8RH Quad8 8-node biquadratic axisymmetric quadrilateral, hybrid, linear pressure, reduced integration
CAX8RHT Quad8 8-node axisymmetric thermally coupled quadrilateral, biquadratic displacement, bilinear temperature, hybrid, linear pressure, reduced integration
CAX8RT Quad8 8-node axisymmetric thermally coupled quadrilateral, biquadratic displacement, bilinear temperature, reduced integration
CAX8T Quad8 8-node axisymmetric thermally coupled quadrilateral, biquadratic displacement, bilinear temperature
CAXA41 Quad4
CAXA4H1 Quad4
CAXA4R1 Quad4
CAXA4RH1 Quad4
CAXA81 Quad8
CAXA8H1 Quad8
CAXA8P1 Quad8
CAXA8R1 Quad8
CAXA8R4 Quad8
CAXA8RH1 Quad8
CAXA8RH4 Quad8
CAXA8RP1 Quad8
CCL12 Hex8 12-node cylindrical brick
CGAX3 Tria3 3-node generalized linear axisymmetric triangle, twist
CGAX3H Tria3 3-node generalized linear axisymmetric triangle, hybrid, constant pressure, twist
CGAX4 Quad4 4-node generalized bilinear axisymmetric quadrilateral, twist
CGAX4H Quad4 4-node generalized bilinear axisymmetric quadrilateral, hybrid, constant pressure, twist
CGAX4R Quad4 4-node generalized bilinear axisymmetric quadrilateral, reduced integration, hourglass control, twist
CGAX4RH Quad4 4-node generalized bilinear axisymmetric quadrilateral, hybrid, constant pressure, reduced integration, hourglass control, twist
CGAX6 Tria6 6-node generalized quadratic axisymmetric triangle, twist
CGAX6H Tria6 6-node generalized quadratic axisymmetric triangle, hybrid, linear pressure, twist
CGAX8 Quad8 8-node generalized biquadratic axisymmetric quadrilateral, twist
CGAX8H Quad8 8-node generalized biquadratic axisymmetric quadrilateral, hybrid, linear pressure, twist
CGAX8R Quad8 8-node generalized biquadratic axisymmetric quadrilateral, reduced integration, twist
CGAX8RH Quad8 8-node generalized biquadratic axisymmetric quadrilateral, hybrid, linear pressure, reduced integration, twist
CGAX8T Quad8 8-node generalized axisymmetric thermally coupled quadrilateral, biquadratic displacement, bilinear temperature, twist
COH2D4 Quad4 4-node two-dimensional cohesive element
COH3D6 Penta6 6-node three-dimensional cohesive element
COH3D8 Hex8 8-node three-dimensional cohesive element
COHAX4 Quad4 4-node axisymmetric cohesive element
CONN2D2
  • Mass
  • Rod
Connector element in a plane between two nodes or ground and a node
CONN3D2
  • Mass
  • Rod
Connector element in space between two nodes or ground and a node
COUP_DIS rbe3
COUP_KIN Rigid
CPE Quad4
CPE3 Tria3 3-node linear plane strain triangle
CPE3E Tria3 3-node linear plane strain piezoelectric triangle
CPE3H Tria3 3-node linear plane strain triangle, hybrid, constant pressure
CPE4E Quad4 4-node bilinear plane strain piezoelectric quadrilateral
CPE4HT Quad4 4-node plane strain thermally coupled quadrilateral, bilinear displacement and temperature, hybrid, constant pressure
CPE4I Quad4 4-node bilinear plane strain quadrilateral, incompatible modes
CPE4IH Quad4 4-node bilinear plane strain quadrilateral, hybrid, linear pressure, incompatible modes
CPE4P Quad4 4-node plane strain quadrilateral, bilinear displacement, bilinear pore pressure
CPE4PH Quad4 4-node plane strain quadrilateral, bilinear displacement, bilinear pore pressure, hybrid, constant pressure
CPE4R Quad4 4-node bilinear plane strain quadrilateral, reduced integration, hourglass control
CPE4RH Quad4 4-node bilinear plane strain quadrilateral, hybrid, constant pressure, reduced integration, hourglass control
CPE4RP Quad4 4-node plane strain quadrilateral, bilinear displacement, bilinear pore pressure, reduced integration, hourglass control
CPE4RPH Quad4 4-node plane strain quadrilateral, bilinear displacement, bilinear pore pressure, hybrid, constant pressure, reduced integration, hourglass control
CPE4T Quad4 4-node plane strain thermally coupled quadrilateral, bilinear displacement and temperature
CPE6 Tria6 6-node quadratic plane strain triangle
CPE6H Tria6 6-node quadratic plane strain triangle, hybrid, linear pressure
CPE6M Tria6 6-node modified quadratic plane strain triangle, hourglass control
CPE6MH Tria6 6-node modified quadratic plane strain triangle, hybrid, linear pressure, hourglass control
CPE6MP Tria6 6-node modified displacement and pore pressure plane strain triangle, hourglass control
CPE6MPH Tria6 6-node modified displacement and pore pressure plane strain triangle, hybrid, linear pressure, hourglass control
CPE8 Quad8 8-node biquadratic plane strain quadrilateral
CPE8H Quad8 8-node biquadratic plane strain quadrilateral, hybrid, linear pressure
CPE8P Quad8 8-node plane strain quadrilateral, biquadratic displacement, bilinear pore pressure
CPE8PH Quad8 8-node plane strain quadrilateral, biquadratic displacement, bilinear pore pressure, hybrid, linear pressure stress
CPE8R Quad8 8-node biquadratic plane strain quadrilateral, reduced integration
CPE8RH Quad8 8-node biquadratic plane strain quadrilateral, hybrid, linear pressure, reduced integration
CPE8RP Quad8 8-node plane strain quadrilateral, biquadratic displacement, bilinear pore pressure, reduced integration
CPE8RPH Quad8 8-node biquadratic displacement, bilinear pore pressure, reduced integration, hybrid, linear pressure
CPEG3 Tria3 3-node linear generalized plane strain triangle
CPEG4R Quad4 4-node bilinear generalized plane strain quadrilateral, reduced integration, hourglass control
CPH4H Quad4
CPS3 Tria3 3-node linear plane stress triangle
CPS3E   3-node linear plane stress piezoelectric triangle
CPS4 Quad4 4-node bilinear plane stress quadrilateral
CPS4E Quad4 4-node bilinear plane stress piezoelectric quadrilateral
CPS4I Quad4 4-node bilinear plane stress quadrilateral, incompatible modes
CPS4R Quad4 4-node bilinear plane stress quadrilateral, reduced integration, hourglass control
CPS4T Quad4 4-node plane stress thermally coupled quadrilateral, bilinear displacement and temperature
CPS6 Tria6 6-node quadratic plane stress triangle
CPS6M Tria6 6-node modified second-order plane stress triangle, hourglass control
CPS8 Quad8 8-node biquadratic plane stress quadrilateral
CPS8R Quad8 8-node biquadratic plane stress quadrilateral, reduced integration
DASHPOT1 Mass Dashpot between a node and ground, acting in a fixed direction
DASHPOT2 Spring Dashpot between two nodes, acting in a fixed direction
DASHPOTA Spring Axial dashpot between two nodes, whose line of action is the line joining the two nodes
DC1D2 Bar2 2-node heat transfer link
DC1D3 Bar3 3-node heat transfer link
DC2D3 Tria3 3-node linear heat transfer triangle
DC2D3E Tria3 3-node linear coupled thermal-electrical triangle
DC2D4 Quad4 4-node linear heat transfer quadrilateral
DC2D4E Quad4 4-node linear coupled thermal-electrical quadrilateral
DC2D6 Tria6 6-node quadratic heat transfer triangle
DC2D6E Tria6 6-node quadratic coupled thermal-electrical triangle
DC2D8 Quad8 8-node quadratic heat transfer quadrilateral
DC2D8E Quad8 8-node quadratic coupled thermal-electrical quadrilateral
DC3D10 Tetra10 10-node quadratic heat transfer tetrahedron
DC3D10E Tetra10 10-node quadratic coupled thermal-electrical tetrahedron
DC3D15 Penta15 15-node quadratic heat transfer triangular prism
DC3D15E Penta15 15-node quadratic coupled thermal-electrical triangular prism
DC3D20 Hex20 20-node quadratic heat transfer brick
DC3D20E Hex20 20-node quadratic coupled thermal-electrical brick
DC3D4 Tetra4 4-node linear heat transfer tetrahedron
DC3D4E Tetra4 4-node linear coupled thermal-electrical tetrahedron
DC3D6 Penta6 6-node linear heat transfer triangular prism
DC3D6E Penta6 6-node linear coupled thermal-electrical triangular prism
DC3D8 Hex8 8-node linear heat transfer brick
DC3D8E Hex8 8-node linear coupled thermal-electrical brick
DCAX3 Tria3 3-node linear axisymmetric heat transfer triangle
DCAX3E Tria3 3-node linear axisymmetric coupled thermal-electrical triangle
DCAX4 Quad4 4-node linear axisymmetric heat transfer quadrilateral
DCAX4E Quad4 4-node linear axisymmetric coupled thermal-electrical quadrilateral
DCAX6 Tria6 6-node quadratic axisymmetric heat transfer triangle
DCAX6E Tria6 6-node quadratic axisymmetric coupled thermal-electrical triangle
DCAX8 Quad8 8-node quadratic axisymmetric heat transfer quadrilateral
DCAX8E Quad8 8-node quadratic axisymmetric coupled thermal-electrical quadrilateral
DCC3D8 Hex8 8-node convection/diffusion brick
DCC3D8D Hex8 8-node convection/diffusion brick, dispersion control
DCCAX4 Quad4 4-node axisymmetric convection/diffusion quadrilateral
DCCAX4D Quad4 4-node axisymmetric convection/diffusion quadrilateral, dispersion control
DCOUP2D rbe3 Two-dimensional distributing coupling element
DCOUP3D rbe3 Three-dimensional distributing coupling element
DS3 Tria3 3-node heat transfer triangular shell
DS4 Quad4 4-node heat transfer quadrilateral shell
DS6 Tria6 6-node heat transfer triangular shell
DS8 Quad8 8-node heat transfer quadrilateral shell
EC3D8R Hex8
EC3D8RT Hex8
ELBOW31 Bar2 2-node pipe in space with deforming section, linear interpolation along the pipe
ELBOW31B Bar2 2-node pipe in space with ovalization only, axial gradients of ovalization neglected
ELBOW31C Bar2 2-node pipe in space with ovalization only, axial gradients of ovalization neglected
ELBOW32 Bar3 3-node pipe in space with deforming section, quadratic interpolation along the pipe
F2D2 Bar2
F3D3 Tria3 3-node linear 3-D triangular hydrostatic fluid element
F3D4 Quad4 4-node linear 3-D quadrilateral hydrostatic fluid element
FAX2 Bar2 2-node linear axisymmetric hydrostatic fluid element
FC3D4 Tetra4
FC3D5 Pyramid5
FC3D6 Penta6
FC3D8 Hex8
GAPCYL Gap Cylindrical gap between two nodes
GAPSPHER Gap Spherical gap between two nodes
GAPUNI Gap Unidirectional gap between two nodes
GK2D2 Rod 2-node two-dimensional gasket element
GK2D2N Rod 2-node two-dimensional gasket element with thickness-direction behavior only
GK3D12M Penta6 12-node three-dimensional gasket element
GK3D12MN Penta6 12-node three-dimensional gasket element with thickness-direction behavior only
GK3D18 Hex8 18-node three-dimensional gasket element
GK3D18N Hex8 18-node three-dimensional gasket element with thickness-direction behavior only
GK3D2 Bar2 2-node three-dimensional gasket element
GK3D2N Bar2 2-node three-dimensional gasket element with thickness-direction behavior only
GK3D4L Quad4 4-node three-dimensional line gasket element
GK3D4LN Quad4 4-node three-dimensional line gasket element with thickness-direction behavior only
GK3D6 Penta6 6-node three-dimensional gasket element
GK3D6N Penta6 6-node three-dimensional gasket element with thickness-direction behavior only
GK3D8 Hex8 8-node three-dimensional gasket element
GK3D8N Hex8 8-node three-dimensional gasket element with thickness-direction behavior only
GKPE4 Quad4 4-node plane strain gasket element
GKPS4 Quad4 4-node plane stress gasket element
GKPS4N Quad4 4-node two-dimensional gasket element with thickness-direction behavior only
HMCONN Mass
ITS
ITSCYL Rod Cylindrical geometry tube support interaction element
ITSUNI Rod Unidirectional tube support interaction element
ITT21 Mass Tube-tube element for use with first-order, 2-D beam and pipe elements
ITT31 Mass Tube-tube element for use with first-order, 3-D beam and pipe elements
JOINTC Spring Three-dimensional joint interaction element
KINCOUP Rigid
LINK Rigid
M3D3 Tria3 3-node triangular membrane
M3D4 Quad4 4-node quadrilateral membrane
M3D4R Quad4 4-node quadrilateral membrane, reduced integration, hourglass control
M3D6 Tria6 6-node triangular membrane
M3D8 Quad8 8-node quadrilateral membrane
M3D8R Quad8 8-node quadrilateral membrane, reduced integration
MASS Mass Point mass
MGAX1 Rod 2-node linear axisymmetric membrane, twist
MGAX2 Bar3 3-node quadratic axisymmetric membrane, twist
PC3D Mass
PIN Rigid
PIPE21 Bar2 2-node linear pipe in a plane
PIPE21H Bar2 2-node linear pipe in a plane, hybrid formulation
PIPE22 Bar3 3-node quadratic pipe in a plane
PIPE22H Bar3 3-node quadratic pipe in a plane, hybrid formulation
PIPE31 Bar2 2-node linear pipe
PIPE31H Bar2 2-node linear pipe in space, hybrid formulation
PIPE32 Bar3 3-node quadratic pipe in space
PIPE32H Bar3 3-node quadratic pipe in space, hybrid formulation
R2D2 Rigid
R3D3 Tria3 3-node 3-D rigid triangular facet
R3D4 Quad4 4-node 3-D bilinear rigid quadrilateral
RAX2 Rigid
RB2D2 Rigid
RB3D2 Rigid 2-node 3-D rigid beam
RDE
  • Rigid
  • rbe3
2-node linear axisymmetric rigid link (for use in axisymmetric planar geometries)
ROTARYI Mass Rotary inertia at a point
S3 Tria3 3-node triangular general-purpose shell, finite membrane strains
S3R Tria3 3-node triangular general-purpose shell, finite membrane strains
S3RS Tria3
S3RT Tria3 3-node thermally coupled triangular general-purpose shell, finite membrane strains
S4 Quad4 4-node general-purpose shell, finite membrane strains
S4R Quad4 4-node general-purpose shell, reduced integration, hourglass control, finite membrane strains
S4R5 Quad4 4-node thin shell, reduced integration, hourglass control, using five degrees of freedom per node
S4RS Quad4
S4RSW Quad4
S4RT Quad4 4-node thermally coupled general-purpose shell, reduced integration, hourglass control, finite membrane strains
S4T Quad4 4-node thermally coupled general-purpose shell, finite membrane strains
S8R Quad8 8-node doubly curved thick shell, reduced integration
S8R5 Quad8 8-node doubly curved thin shell, reduced integration, using five degrees of freedom per node
S8RT Quad8 8-node thermally coupled quadrilateral general thick shell, biquadratic displacement, bilinear temperature in the shell surface
SAX1 Bar2 2-node linear axisymmetric thin or thick shell
SAX2 Bar3 3-node quadratic axisymmetric thin or thick shell
SC6R Penta6 6-node triangular in-plane continuum shell wedge, general-purpose continuum shell, finite membrane strains
SC6RT Penta6 6-node linear displacement and temperature, triangular in-plane continuum shell wedge, general-purpose continuum shell, finite membrane strains
SC8R Hex8 8-node quadrilateral in-plane general-purpose continuum shell, reduced integration with hourglass control, finite membrane strains
SC8RT Hex8 8-node linear displacement and temperature, quadrilateral in-plane general-purpose continuum shell, reduced integration with hourglass control, finite membrane strains
SFM3D3 Tria3 3-node triangular surface element
SFM3D4 Quad4 4-node quadrilateral surface element
SFM3D4R Quad4 4-node quadrilateral surface element, reduced integration
SFM3D6 Tria6 6-node triangular surface element
SFM3D8 Quad8 8-node quadrilateral surface element
SFM3D8R Quad8 8-node quadrilateral surface element, reduced integration
SFMAX1 Rod 2-node linear axisymmetric surface element
SFMAX2 Bar3 3-node quadratic axisymmetric surface element
SFMGAX1 Rod 2-node linear axisymmetric surface element, twist
SFMGAX2 Bar3 3-node quadratic axisymmetric surface element, twist
SPRING1 Mass Spring between a node and ground, acting in a fixed direction
SPRING2 Spring Spring between two nodes, acting in a fixed direction
SPRINGA Spring Axial spring between two nodes, whose line of action is the line joining the two nodes
STRI3 Tria3 3-node triangular facet thin shell
STRI65 Tria6 6-node triangular thin shell, using five degrees of freedom per node
T2D2 Rod 2-node linear 2-D truss
T2D2E Rod 2-node 2-D piezoelectric truss
T2D2H Rod 2-node linear 2-D truss, hybrid
T2D2T Rod 2-node 2-D thermally coupled truss
T2D3 Rod 3-node quadratic 2-D truss
T3D2 Rod 2-node linear 3D truss
T3D2E Rod 2-node 3D piezoelectric truss
T3D2H Rod 2-node linear 3D truss, hybrid
T3D2T Rod 2-node 3D thermally coupled truss
TIE Rigid
ANSYS Cards
BEAM3 Bar2 2D Elastic Beam
Config 60, Type 2
BEAM4 Bar2 3D Elastic Beam
Config 60, Type 1
BEAM23 Bar2 2D Plastic Beam
Config 60, Type 9
BEAM24 Bar2 3D Thin-walled Beam
Config 60, Type 6
BEAM44 Bar2 3D Elastic Tapered Unsymmetric Beam
Config 60, Type 7
BEAM54 Bar2 2D Elastic Tapered Unsymmetric Beam
Config 60, Type 10
BEAM188 Bar2 3D Linear Finite Strain Beam
Config 60, Type 8
BEAM189 Bar3 3D Quadratic Finite Strain Beam
Config 63, Type 1
CERIG Rigid Ldof, Ldof2, Ldof3, Ldof4, Ldof5
Config 5, Type 1, 2
CIRCU124 Rod General circuit element applicable to circuit simulation.
COMBIN14 Spring Spring-Damper
Config 21, Type 1
COMBIN39 Spring Nonlinear Spring
Config 21, Type 2
COMBIN40 Spring Combination
Config 21, Type 3
CONTA171 Plot 2D 2-Node Surface-to-Surface Contact
Config 2, Type 3
CONTA172 Bar3 2D 3-Node Surface-to-Surface Contact
Config 63, Type 12
CONTA173
  • Tria3
  • Quad4
3D 4-Node Surface-to-Surface Contact
  • Config 103, Type 13
  • Config 104, Type 13
CONTA174
  • Tria6
  • Quad 8
3D 8-Node Surface-to-Surface Contact
  • Config 106, Type 10
  • Config 108, Type 10
CONTA175 Mass 2D/3D Node-to-Surface Contact
Config 1, Type 14
CONTA177
  • Bar2
  • Bar3
3D Line-to-Surface Contact
CONTA178 Gap 3D Node-to-Node Contact
Config 70, Type 3
CONTAC12 Gap 2D Point-to-Point Contact
Config 70, Type 2
CONTAC48 Tria3
CONTAC49
  • Tria3
  • Quad4
CONTAC52 Gap 3D Point-to-Point Contact
Config 70, Type 1
CP Rigid Defines (or modifies) a set of coupled degrees of freedom.
Config 55, Type 1, 2
CP_ELEC Rigid
CP_STRUC Rigid
CP_THERM Rigid
ELBOW290 Bar3
FLUID29
  • Tria3
  • Quad4
2D Axisymmetric Harmonic Acoustic Fluid
FLUID30
  • Tetra4
  • Penta6
  • Hex8
3D Acoustic Fluid
FLUID80 Hex8 3D Contained Fluid
Config 208, Type 9
FLUID116 Rod Coupled Thermal-Fluid Pipe
Config 61, Type 12
FLUID220
  • Hex20
  • Penta15
  • Pyramid13
  • Tetra10
FLUID221 Tetra10
HF118
  • Tria6
  • Quad8
2D High-Frequency Quadrilateral Solid
  • Config 106, Type 25
  • Config 108, Type 25
HF119 Tetra10 3D High-Frequency Tetrahedral Solid
Config 210, Type 11
HF120
  • Pyramid13
  • Penta15
  • Hex20
3D High-Frequency Brick Solid
  • Config 213, Type 3
  • Config 215, Type 3
  • Config 220, Type 3
HYPER58
  • Tetra4
  • Penta6
  • Hex8
3D 8-Node Mixed u-P Hyperelastic Solid
  • Config 204, Type 11
  • Config 206, Type 11
  • Config 208, Type 11
INFIN9 Rod
INFIN110
  • Quad4
  • Quad8
INTER192
  • Quad4
  • Tria3
INTER193 Quad8
INTER194
  • Hex20
  • Penta15
INTER195
  • Hex8
  • Penta6
INTER205
  • Hex8
  • Penta6
LINK1 Rod 2D Spar (or Truss)
Config 61, Type 5
LINK8 Rod 3D Spar (or Truss)
Config 61, Type 1
LINK10 Rod Tension-only or Compression-only Spar
Config 61, Type 2
LINK11 Bar2 Linear actuator
Config 61, Type 25
LINK31 Rod Radiation Link
Config 61, Type 6
LINK32 Rod 2D Conduction Bar
Config 61, Type 7
LINK33 Rod 3D Conduction Bar
Config 61, Type 8
LINK34 Rod Convection Link
Config 61, Type 9
LINK68 Rod Coupled Thermal-Electric Line
Config 61, Type 14
LINK180 Rod 3D Finite Strain Spar (or Truss)
Config 61, Type 11
MASS21 Mass Structural Mass
Config 1, Type 1
MASS71 Mass Thermal Mass
Config 1, Type 2
MESH200
  • Bar3
  • Rod
  • Tria3
  • Tetra4
  • Tetra10
  • Quad4
  • Hex8
  • Tria6
  • Quad8
  • Hex20
Meshing Facet
  • Config 63, Type 26
  • Config 61, Type 26
  • Config 103, Type 26
  • Config 204, Type 26
  • Config 210, Type 26
  • Config 104, Type 26
  • Config 208, Type 26
  • Config 106, Type 26
  • Config 108, Type 26
  • Config 220, Type 26
MPC184 Rod Multipoint Constraint Elements: Rigid Link, Rigid Beam, Slider, Spherical, Revolute, Universal
Config 61, Type 13
PIPE16 Bar2 Elastic Straight Pipe
Config 60, Type 3
PIPE18 Bar2 Elastic Curved Pipe (Elbow)
Config 60, Type 4
PIPE20 Rod Plastic Straight Pipe
Config 61, Type 4
PIPE60 Bar2 Plastic Curved Pipe (Elbow)
Config 60, Type 5
PIPE288 Bar2
PIPE289 Bar3
PLANE2 Tria6 2D 6-Node Triangular Structural Solid
Config 106, Type 21
PLANE13
  • Quad4
  • Tria3
2D Coupled-Field Solid
  • Config 103, Type 3
  • Config 104, Type 3
PLANE25
  • Tria3
  • Quad4
Axisymmetric-Harmonic 4-Node Structural Solid
  • Config 103, Type 6
  • Config 104, Type 6
PLANE35 Tria6 2D 6-Node Triangular Thermal Solid
Config 106, Type 7
PLANE42
  • Tria3
  • Quad4
2D Structural Solid
  • Config 103, Type 4
  • Config 104, Type 4
PLANE53
  • Tria6
  • Quad8
2D 8-Node Magnetic Solid
  • Config 106, Type 9
  • Config 108, Type 9
PLANE55
  • Tria3
  • Quad4
2D Thermal Solid
  • Config 103, Type 5
  • Config 104, Type 5
PLANE67
  • Tria3
  • Quad4
2D Coupled Thermal-Electric Solid
  • Config 103, Type 21
  • Config 104, Type 21
PLANE75
  • Tria3
  • Quad4
Axisymmetric-Harmonic 4-Node Thermal Solid
  • Config 103, Type 9
  • Config 104, Type 9
PLANE77
  • Tria6
  • Quad8
2D 8-Node Thermal Solid
PLANE78
  • Tria6
  • Quad8
Axisymmetric-Harmonic 8-Node Thermal Solid
  • Config 106, Type 8
  • Config 108, Type 8
PLANE82
  • Tria6
  • Quad8
2D 8-Node Structural Solid
PLANE83
  • Tria6
  • Quad8
Axisymmetric-Harmonic 8-Node Structural Solid
  • Config 106, Type 3
  • Config 108, Type 3
PLANE121
  • Tria6
  • Quad8
2D 8-Node Electrostatic Solid
  • Config 106, Type 22
  • Config 108, Type 22
PLANE145
  • Tria6
  • Quad8
2D Quadrilateral Structural Solid p-Element
  • Config 106, Type 23
  • Config 108, Type 23
PLANE146 Tria6 Config 106, Type 31
PLANE162
  • Tria3
  • Quad4
Explicit 2D Structural Solid
  • Config 103, Type 22
  • Config 104, Type 22
PLANE182
  • Tria3
  • Quad4
2D 4-Node Structural Solid
  • Config 103, Type 23
  • Config 104, Type 23
PLANE183
  • Tria6
  • Quad8
  • Config 106, Type 19
  • Config 108, Type 19
PLANE223
  • Tria6
  • Quad8
2D 8-Node Coupled-Field Solid
PRETS179 Bar2 Define a 2D or 3D pretension section within a meshed structure.
Config 60, Type 17
RBE3 RBE3 Distributes the force/moment applied at the master node to a set of slave nodes, taking into account the geometry of the slave nodes as well as weighting factors.
SHELL28 Quad4 Shear/Twist Panel
Config 104, Type 12
SHELL41
  • Tria3
  • Quad4
Membrane Shell
  • Config 103, Type 19
  • Config 104, Type 19
SHELL43
  • Tria3
  • Quad4
4-Node Plastic Large Strain Shell
SHELL51 Bar2 Axisymmetric Structural Shell
Config 60, Type 14
SHELL57
  • Tria3
  • Quad4
Thermal Shell
  • Config 103, Type 7
  • Config 104, Type 7
SHELL61 Bar2 Axisymmetric-Harmonic Structural Shell
Config 60, Type 15
SHELL63
  • Tria3
  • Quad4
Elastic Shell
SHELL91
  • Tria6
  • Quad8
Nonlinear Layered Structural Shell
  • Config 106, Type 6
  • Config 108, Type 6
SHELL93
  • Tria6
  • Quad8
8-Node Structural Shell
  • Config 106, Type 4
  • Config 108, Type 4
SHELL99
  • Tria6
  • Quad8
Linear Layered Structural Shell
  • Config 106, Type 5
  • Config 108, Type 5
SHELL131
  • Tria3
  • Quad4
4-Node Layered Thermal Shell
  • Config 103, Type 25
  • Config 104, Type 25
SHELL132
  • Tria6
  • Quad8
8-Node Layered Thermal Shell
  • Config 106, Type 24
  • Config 108, Type 24
SHELL143
  • Tria3
  • Quad4
4-Node Plastic Small Strain Shell
  • Config 103, Type 10
  • Config 104, Type 10
SHELL150
  • Tria6
  • Quad8
8-Node Structural Shell p-Element
  • Config 106, Type 20
  • Config 108, Type 20
SHELL157
  • Tria3
  • Quad4
Thermal-Electric Shell
  • Config 103, Type 20
  • Config 104, Type 20
SHELL163
  • Tria3
  • Quad4
Explicit Thin Structural Shell
  • Config 103, Type 17
  • Config 104, Type 17
SHELL181
  • Tria3
  • Quad4
4-Node Finite Strain Shell
  • Config 103, Type 11
  • Config 104, Type 11
SHELL208 Bar2 2-Node Finite Strain Axisymmetric Shell
SHELL209 Bar2 3-Node Finite Strain Axisymmetric Shell
SHELL281
  • Tria6
  • Quad8
8-Node Finite Strain Shell
SOLID5
  • Penta6
  • Hex8
3D Coupled-Field Solid
  • Config 206, Type 2
SOLID45
  • Tetra4
  • Penta6
  • Hex8
3D Structural Solid
SOLID46
  • Tetra4
  • Penta6
  • Hex8
3D 8-Node Layered Structural Solid
  • Config 204, Type 6
  • Config 206, Type 6
  • Config 208, Type 6
SOLID62
  • Tetra4
  • Pyramid5
  • Penta6
  • Hex8
3D Magneto-Structural Solid
  • Config 204, Type 15
  • Config 205, Type 15
  • Config 206, Type 15
  • Config 208, Type 15
SOLID64
  • Tetra4
  • Penta6
  • Hex8
3D Anisotropic Structural Solid
  • Config 204, Type 7
  • Config 206, Type 7
  • Config 208, Type 7
SOLID69
  • Tetra4
  • Penta6
  • Hex8
3D Coupled Thermal-Electric Solid
  • Config 204, Type 4
  • Config 206, Type 4
  • Config 208, Type 4
SOLID70
  • Tetra4
  • Penta6
  • Hex8
3D Thermal Solid
  • Config 204, Type 3
  • Config 206, Type 3
  • Config 208, Type 3
SOLID72 Tetra4
SOLID73
  • Tetra4
  • Penta6
  • Hex8
SOLID87 Tetra10 3D 10-Node Tetrahedral Thermal Solid
Config 210, Type 5
SOLID90
  • Tetra10
  • Pyramid13
  • Penta15
  • Hex20
3D 20-Node Thermal Solid
  • Config 213, Type 2
SOLID92 Tetra10 3D 10-Node Tetrahedral Structural Solid
Config 210, Type 3
SOLID95
  • Tetra10
  • Pyramid13
  • Penta15
  • Hex20
3D 20-Node Structural Solid
  • Config 210, Type 1
  • Config 213, Type 1
  • Config 215, Type 1
  • Config 220, Type 1
SOLID96
  • Tetra4
  • Pyramid5
  • Penta6
  • Hex8
3D Magnetic Scalar Solid
  • Config 204, Type 5
  • Config 205, Type 5
  • Config 206, Type 5
  • Config 208, Type 5
SOLID97
  • Tetra4
  • Pyramid5
  • Penta6
  • Hex8
3D Magnetic Solid
  • Config 204, Type 8
  • Config 205, Type 8
  • Config 206, Type 8
  • Config 208, Type 8
SOLID98 Tetra10 Tetrahedral Coupled-Field Solid
Config 210, Type 4
SOLID117
  • Tetra10
  • Pyramid13
  • Penta15
  • Hex20
3D 20-Node Magnetic Solid
  • Config 210, Type 8
  • Config 213, Type 8
  • Config 215, Type 8
  • Config 220, Type 8
SOLID147
  • Penta15
  • Hex20
3D Brick Structural Solid p-Element
SOLID148
  • Penta15
  • Tetra10
  • Hex20
3D Tetrahedral Structural Solid p-Element
  • Config 215, Type 9
  • Config 210, Type 9
  • Config 220, Type 9
SOLID164
  • Tetra4
  • Pyramid5
  • Penta5
  • Hex8
Explicit 3D Structural Solid
  • Config 204, Type 14
  • Config 205, Type 14
  • Config 206, Type 14
  • Config 208, Type 14
SOLID168 Tetra10 Explicit 3D 10-Node Tetrahedral Structural Solid
SOLID185
  • Tetra4
  • Penta6
  • Hex8
3D 8-Node Structural Solid
  • Config 204, Type 13
  • Config 206, Type 13
  • Config 208, Type 13
SOLID186
  • Tetra10
  • Pyramid13
  • Penta15
  • Hex20
  • Config 210, Type 7
  • Config 213, Type 7
  • Config 215, Type 7
  • Config 220, Type 7
SOLID187 Tetra10 3D 10-Node Tetrahedral Structural Solid
Config 210, Type 6
SOLID191
  • Tetra10
  • Penta15
  • Hex20
3D 20-Node Layered Structural Solid
  • Config 210, Type 10
  • Config 215, Type 10
  • Config 220, Type 10
SOLID226
  • Tetra10
  • Pyramid13
  • Penta15
  • Hex20
3D 20-Node Coupled-Field Solid
SOLID227 Tetra10 3D 10-Node Coupled-Field Solid
SOLID278
  • Hex8
  • Penta6
  • Tetra4
SOLID279
  • Hex20
  • Penta15
  • Pyramid13
  • Tetra10
SOLID285 Tetra4
SOLSH190
  • Penta6
  • Hex8
3D 8-Node Layered Solid Shell
  • Config 206
  • Config 208, Type 17
SURF151 Bar2 2D Thermal Surface Effect
Config 60, Type 12
SURF152
  • Quad4
  • Quad8
  • Tria6
3D Thermal Surface Effect
  • Config 104, Type 14
  • Config 108, Type 14
SURF153
  • Bar2
  • Bar3
2D Structural Surface Effect
  • Config 60, Type 16
  • Config 63, Type 16
SURF154
  • Quad4
  • Quad8
  • Tria6
3D Structural Surface Effect
  • Config 104, Type 18
  • Config 108, Type 18
SURF156 Bar3 3D Structural Surface Line Load Effect
SURF251 Rod 2D Radiosity Surface
Config 61, Type 25
SURF252
  • Tria3
  • Quad4
3D Radiosity Surface
  • Config 103, Type 36
  • Config 104, Type 36
TARGE169
  • Mass
  • Bar2
  • Bar3
2D Target Segment
  • Config 1, Type 13
  • Config 60, Type 9
TARGE170
  • Mass
  • Tria3
  • Quad4
  • Tria6
  • Quad8
3D Target Segment
  • Config 103, Type 16
  • Config 104, Type 16
  • Config 106, Type 16
  • Config 108, Type 16
VISCO88
  • Tria6
  • Quad8
2D 8-Node Viscoelastic Solid
VISCO107
  • Tetra4
  • Penta6
  • Hex8
3D 8-Node Viscoplastic Solid
  • Config 204, Type 16
  • Config 206, Type 16
  • Config 208, Type 16
EXODUS Cards
BEAM bar2
BEAM2 bar2
BEAM3 bar3
CIRCLE mass
HEX20 hex20
HEX8 hex8
PYRAMID13 pyramid13
PYRAMID5 pyramid5
QUAD4 quad4
QUAD8 quad8
RBAR weld
RJOINT rigid
RROD rigid
SHELL3 tria3
SHELL4 quad4
SHELL6 tria6
SHELL8 quad8
SPHERE mass
SPRING spring
TETRA10 tetra10
TETRA4 tetra4
TRI3 tria3
TRI6 tria6
TRIANGLE3 tria3
TRIANGLE6 tria6
TRUSS rod
WEDGE15 penta15
WEDGE6 penta6
LS-DYNA Cards
*CONSTRAINED_GENERALIZED_WELD_BUTT_(ID) Rigid Define butt welds.
Spot(default)/type 1, Fillet/type 2, and Butt/type 3 failure modes are supported. Failure information is based on weld type selected. Coordinate System ID can be selected.
No Failure/Type 0 Card 36 entities are defined as *CONSTRAINED_NODAL_RIGID_BODIES in Keyword. They are a separate element type.
*CONSTRAINED_GENERALIZED_WELD_COMBINED_(ID) Rigid Define combined welds.
*CONSTRAINED_GENERALIZED_WELD_CROSS_FILLET_(ID) Rigid Define cross fillet welds.
*CONSTRAINED_GENERALIZED_WELD_FILLET_(ID) Rigid Define fillet welds.
*CONSTRAINED_GENERALIZED_WELD_SPOT_(ID) Rigid Define spot welds.
*CONSTRAINED_INTERPOLATION RBE3 Define an interpolation constrain.
*CONSTRAINED_JOINT_CONSTANT_VELOCITY Joint
*CONSTRAINED_JOINT_CYLINDRICAL Joint Define a joint between two rigid bodies.
*CONSTRAINED_JOINT_CYLINDRICAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_CYLINDRICAL_LOCAL(ID) Joint
*CONSTRAINED_JOINT_CYLINDRICAL_LOCAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_GEARS Joint
*CONSTRAINED_JOINT_LOCKING(ID) Joint
*CONSTRAINED_JOINT_LOCKING_FAILURE(ID) Joint
*CONSTRAINED_JOINT_LOCKING_LOCAL(ID) Joint
*CONSTRAINED_JOINT_LOCKING_LOCAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_PLANAR(ID) Joint
*CONSTRAINED_JOINT_PLANAR_FAILURE(ID) Joint
*CONSTRAINED_JOINT_PLANAR_LOCAL(ID) Joint
*CONSTRAINED_JOINT_PLANAR_FAILURE_LOCAL(ID) Joint
*CONSTRAINED_JOINT_PULLY Joint
*CONSTRAINED_JOINT_RACK_AND_PINION_ID Joint
*CONSTRAINED_JOINT_REVOLUTE Joint
*CONSTRAINED_JOINT_REVOLUTE_LOCAL(ID) Joint
*CONSTRAINED_JOINT_REVOLUTE_FAILURE(ID) Joint
*CONSTRAINED_JOINT_REVOLUTE_LOCAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_ROTATIONAL_MOTOR Joint
*CONSTRAINED_JOINT_SCREW
*CONSTRAINED_JOINT_SPHERICAL(ID) Joint
*CONSTRAINED_JOINT_SPHERICAL_LOCAL(ID) Joint
*CONSTRAINED_JOINT_SPHERICAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_SPHERICAL_LOCAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_STIFFNESS_TRANSLATIONAL Joint Define optional rotational and translational joint stiffness for joints defined by *CONSTRAINED_JOINT_OPTION.
*CONSTRAINED_JOINT_TRANSLATIONAL(ID) Joint
*CONSTRAINED_JOINT_TRANSLATIONAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_TRANSLATIONAL_LOCAL(ID) Joint
*CONSTRAINED_JOINT_TRANSLATIONAL_LOCAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_TRANSLATIONAL_MOTOR Joint
*CONSTRAINED_JOINT_UNIVERSAL(ID) Joint
*CONSTRAINED_JOINT_UNIVERSAL_FAILURE(ID) Joint
*CONSTRAINED_JOINT_UNIVERSAL_LOCAL(ID) Joint
*CONSTRAINED_JOINT_UNIVERSAL_LOCAL_FAILURE(ID) Joint
*CONSTRAINED_NODAL_RIGID_BODY Rigid Define a nodal rigid body.
*CONSTRAINED_NODAL_RIGID_BODY (2-Noded) Rigid
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA Rigid Used when inertial properties are defined rather than computed.
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA (2-Noded) Rigid
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA _SPC Rigid
*CONSTRAINED_NODAL_RIGID_BODY_INERTIA _SPC (2-Noded) Rigid
*CONSTRAINED_NODAL_RIGID_BODY_SPC Rigid
*CONSTRAINED_NODAL_RIGID_BODY_SPC (2-Noded) Rigid
*CONSTRAINED_NODE_SET Rigid Define nodal constraint sets for translational motion in global coordinates.
*CONSTRAINED_NODE_SET (2-Noded) Rigid
*CONSTRAINED_NODE_SET_ID Rigid
*CONSTRAINED_RIVET Weld Define massless rivets between non-contiguous nodal pairs.
*CONSTRAINED_SHELL_TO_SOLID Rigid Define a tie between a shell edge and solid elements.
*CONSTRAINED_SPOTWELD_ID Weld Define massless spot welds between non-contiguous nodal pairs.
Normal and shear failure values can be edited.
*CONSTRAINED_SPOTWELD_FILTERED_FORCE_ID Weld
*ELEMENT_BEAM Bar Define two node elements including 3D beams, trusses, 2D axisymmetric shells and 2D plane strain beam elements.
Thickness option can be added. This allows you to edit the parameters based on the element formulation in the property to which the beam points.
*ELEMENT_BEAM_OFFSET Bar
*ELEMENT_BEAM_OFFSET_PID Bar
*ELEMENT_BEAM_OFFSET_THICKNESS Bar
*ELEMENT_BEAM_ORIENTATION Bar
*ELEMENT_BEAM_PID Bar
*ELEMENT_BEAM_PID_ORIENTATION Bar
*ELEMENT_BEAM_PID_SCALAR Bar
*ELEMENT_BEAM_SCALAR Bar
*ELEMENT_BEAM_SCALAR_ORIENTATION Bar
*ELEMENT_BEAM_SECTION Bar
*ELEMENT_BEAM_SECTION_ORIENTATION Bar
*ELEMENT_BEAM_SECTION_PID Bar
*ELEMENT_BEAM_THICKNESS Bar
*ELEMENT_BEAM_THICKNESS_ORIENTATION Bar
*ELEMENT_BEAM_THICKNESS_PID Bar
*ELEMENT_BEAM_THICKNESS_SCALAR Bar
*ELEMENT_DISCRETE Spring Define a discrete (spring or damper) element between two nodes or a node and ground.
Scale factor, printing flags, and offset values can be edited.
*ELEMENT_INERTIA Mass Define a lumped inertia element assigned to a nodal point.
*ELEMENT_INERTIA_OFFSET Mass
*ELEMENT_MASS Mass Define a lumped mass element assigned to a nodal point or equally distributed to the nodes of a node set.
*ELEMENT_MASS_NODE_SET Mass Mass elements defined on node set
*ELEMENT_MASS_PART Mass Define additional non-structural mass to be distributed by an area weighted distribution to all nodes of a given part ID.
*ELEMENT_MASS_PART_SET Mass Mass elements defined on part set.
*ELEMENT_PLOTEL Plot Define a null beam element for visualization.
*ELEMENT_SEATBELT Rod Define a seat belt element.
*ELEMENT_SEATBELT_SENSOR Sensors Define seat belt sensor.
*ELEMENT_SHELL
  • Tria3
  • Quad4
Define three, four, six and eight node elements including 3D shells, membranes, 2D plane stress, plane strain, and axisymmetric solids.
Thickness and beta options can be added singularly or together. This allows you to edit the thickness and material angles to override the SECTION card.
*ELEMENT_SHELL_BETA
  • Tria3
  • Quad4
*ELEMENT_SHELL_BETA_OFFSET
  • Tria3
  • Quad4
*ELEMENT_SHELL_COMPOSITE
  • Tria3
  • Quad4
*ELEMENT_SHELL_DOF
  • Tria3
  • Quad4
*ELEMENT_SHELL_MCID
  • Tria3
  • Quad4
*ELEMENT_SHELL_MCID_OFFSET
  • Tria3
  • Quad4
*ELEMENT_SHELL_OFFSET
  • Tria3
  • Quad4
*ELEMENT_SHELL_THICKNESS
  • Tria3
  • Quad4
*ELEMENT_SHELL_THICKNESS_BETA
  • Tria3
  • Quad4
*ELEMENT_SHELL_THICKNESS_BETA_OFFSET
  • Tria3
  • Quad4
*ELEMENT_SHELL_THICKNESS_MCID
  • Tria3
  • Quad4
*ELEMENT_SHELL_THICKNESS_MCID_OFFSET
  • Tria3
  • Quad4
*ELEMENT_SHELL_THICKNESS_OFFSET
  • Tria3
  • Quad4
*ELEMENT_SOLID
  • Tetra4
  • Penta6
  • Hex8
  • Tetra10
Define three-dimensional solid elements including 4 noded tetrahedrons and 8-noded hexahedrons.
*ELEMENT_SOLID_ORTHO
  • Tetra4
  • Penta6
  • Hex8
  • Tetra10
Define a local coordinate system for orthotropic and anisotropic materials.
*ELEMENT_SOLID_TET4TOTET10 Tetra4 Converts 4 node tetrahedron solids to 10 node quadratic tetrahedron solids.
*ELEMENT_SPH Mass Define a lumped mass element assigned to a nodal point
*ELEMENT_TSHELL
  • Penta6
  • Hex8
Define an eight node thick shell element which is available with either fully reduced or selectively reduced integration rules.
*INITIAL_MOMENTUM
  • Tetra4
  • Penta6
  • Hex8
  • Tetra10
Defines initial momentum in the solid element at the start of analysis. This momentum could be from previous analysis/step carried forward to next analysis/step.
This is supported as an attribute to an element to maintain its associativity with element inside HM.
*INITIAL_STRAIN_SHELL
  • Tria3
  • Quad4
Defines stress in the shell element at the start of analysis. This stress could be from previous analysis/step carried forward to next analysis/step.
*INITIAL_STRAIN_SOLID
  • Tetra4
  • Penta6
  • Hex8
  • Tetra10
Defines stress in the solid element at the start of analysis. This stress could be from previous analysis/step carried forward to next analysis/step.
*INITIAL_STRESS_BEAM Bar Defines stress in the beam element at the start of analysis. This stress could be from previous analysis/step carried forward to next analysis/step.
*INITIAL_STRESS_SHELL
  • Tria3
  • Quad4
*INITIAL_STRESS_SOLID
  • Tetra4
  • Penta6
  • Hex8
  • Tetra10
Nastran Cards
CAABSF
  • Mass
  • Rod
  • Tria3
  • Quad4
Defines a frequency-dependent acoustic absorber element in coupled fluid-structural analysis.
CACINF3 Tria3 Defines an acoustic conjugate infinite element with triangular base.
CACINF4 Quad4 Defines an acoustic conjugate infinite element with quadrilateral base.
CAERO1 Quad4 Defines an aerodynamic macro element (panel) in terms of two leading edge locations and side chords. This is used for Doublet-Lattice theory for subsonic aerodynamics and the ZONA51 theory for supersonic aerodynamics.
CAERO2 Rod Defines aerodynamic slender body and interference elements for Doublet-Lattice aerodynamics.
CBAR Bar Defines a simple beam element.
CBEAM Bar Defines a beam element.
CBEND Bar Defines a curved beam, curved pipe, or elbow element.
CBUSH
  • Mass
  • Spring
Defines a generalized spring-and-damper structural element that may be nonlinear or frequency dependent.
Both elements with grounded terminals are supported.
CBUSH1D
  • Mass
  • Spring
Defines the connectivity of a one-dimensional spring and viscous damper element.
CDAMP1
  • Mass
  • Spring
Defines a scalar damper element.
Elements CDAMP1 and CDAMP2 with grounded terminals are not supported.
CDAMP2
  • Mass
  • Spring
Defines a scalar damper element without reference to a material or property entry.
CDAMP3
  • Mass
  • Spring
Defines a scalar damper element that is connected only to scalar points.
CDAMP4
  • Mass
  • Spring
Defines a scalar damper element that connected only to scalar points and without reference to a material or property entry.
CELAS1
  • Mass
  • Spring
Defines a scalar spring element.
CELAS2
  • Mass
  • Spring
Defines a scalar spring element without reference to a property entry.
CELAS3
  • Mass
  • Spring
Defines a scalar spring element that connects only to scalar points.
CELAS4
  • Mass
  • Spring
Defines a scalar spring element that is connected only to scalar points, without reference to a property entry.
CFAST
  • Mass
  • Rod
Defines a fastener with material orientation connecting two surface patches.
CGAP Gap Defines a gap or friction element.
CHACAB Hex8 Defines the acoustic absorber element in coupled fluid-structural analysis.
CHBDYE
  • Slave3
  • Slave4
Defines a boundary condition surface element with reference to a heat conduction element.
This element is supported as GROUP.
CHBDYG
  • Slave3
  • Slave4
Defines a boundary condition surface element without reference to a property entry.
Creation from scratch is not yet supported.
CHBDYP
  • Mass
  • Rod
Defines a boundary condition surface element with reference to a PHBDY entry.
CONVM is supported as a continuation card inside CHBDYP.
CHEXA (20-noded) Hex20 Defines a second order solid element, composed of 6 quadrilateral faces.
In Nastran, you can define a second order element with missing mid-side nodes. Input data decks containing such elements are read by the translator as a first-order element. A message is written to the nastran.msg file indicating the corresponding element ID.
CHEXA (8-noded) Hex8 Defines a first order solid element, composed of 6 quadrilateral faces.
CMASS1
  • Mass
  • Spring
Defines a scalar mass element.
CMASS2
  • Mass
  • Spring
Defines a scalar mass element without reference to a property entry.
CMASS3
  • Mass
  • Spring
Defines a scalar mass element that is connected only to scalar points.
CMASS4
  • Mass
  • Spring
Defines a scalar mass element that is connected only to scalar points, without reference to a property entry.
CONM1 Mass Defines a 6 x 6 symmetric mass matrix at a geometric grid point.
CONM2 Mass Defines a concentrated mass at a grid point.
CONROD Rod Defines a rod element without reference to a property entry.
CPENTA (6-noded) Penta6 Defines the connections of a five-sided solid element with six to fifteen grid points.
CPENTA (15-noded) Penta15 Defines the connections of a five-sided solid element with six to fifteen grid points.
CQUAD4 Quad4 Defines an isoparametric membrane-bending or plane strain quadrilateral plate element.
CQUAD8 Quad8 Defines a curved quadrilateral shell or plane strain element with eight grid points.
CQUADR Quad4 Defines an isoparametric membrane and bending quadrilateral plate element. However, this element does not include membrane-bending coupling. This element is less sensitive to initial distortion and extreme values of Poisson’s ratio than the CQUAD4 element. It is a companion to the CTRIAR element.
CROD Rod Defines a tension-compression-torsion element.
CSHEAR Quad4 Defines a shear panel element.
CSEAM Rod
CTETRA (4-noded) Tetra4 Defines the connections of the four-sided solid element with four grid points.
CTETRA (10-noded) Tetra10 Defines the connections of the four-sided solid element with ten grid points.
CTRIA3 Tria3 Defines an isoparametric membrane-bending or plane strain triangular plate element.
CTRIA6 Tria6 Defines a curved triangular shell element or plane strain with six grid points.
CTRIAR Tria3 Defines an isoparametric membrane-bending triangular plate element. However, this element does not include membrane-bending coupling. It is a companion to the CQUADR element.
CTRIAX
  • Tria3
  • Tria6
Defines an axisymmetric triangular element with up to 6 grid points for use in fully nonlinear (i.e., large strain and large rotations) hyperelastic analysis
CTRIAX6
  • Tria3
  • Tria6
Defines an isoparametric and axisymmetric triangular cross section ring element with midside grid points.
CTUBE Rod Defines a tension-compression-torsion tube element.
CQUADX
  • Quad4
  • Quad8
Defines an axisymmetric quadrilateral element with up to nine grid points for use in fully nonlinear (i.e. large strain and large rotations) analysis or a linear harmonic or rotor dynamic analysis. The element has between four and eight grid points.
Ninth grid selected in card edit of the element.
CVISC Spring Defines a viscous damper element.
CWELD
  • Mass
  • Rod
Defines a weld or fastener connecting two surface patches or points.
Node-Node, Node-Patch, or Patch-Patch weld elements can be read. CWELD element is stored as an element of the rod configuration. CWELD elements using the ELEMID option not created in HyperMesh will be displayed as zero length. Currently, the Spotweld panel can only create Node-Node and Patch-Patch CWELD elements.
HyperMesh always calculates the location of GA and GB by projecting GS in the normal direction of surface patch A and surface patch B, respectively.
GENEL RBE3 Defines a general element.
HM_SPRING Spring Defines a spring element, which is converted to Nastran entities on export, in a manner similar to that explained in Using HM_ELAS.
MBOLT Mass Defines a bolt for use in SOL 600 in countries outside the USA.
MBOLTUS Mass Defines a bolt for use only in SOL 600 and only in the USA.
PLOTEL Plot Defines a one-dimensional dummy element for use in plotting.
RBAR Weld Defines a rigid bar with six degrees-of-freedom at each end.
RBAR CNA field defaults to 123456. To edit the CNA, CNB, CMA, or CMB fields, you must view the card image for the RBAR element.
RBE2
  • Rigid
  • Rigidlink
Defines a rigid body with independent degrees-of-freedom that are specified at a single grid point and with dependent degrees-of-freedom that are specified at an arbitrary number of grid points.
An RBE2 element with one dependent node is identified as a rigid element, while an element with multiple dependent nodes is identified as a rigid link element.
RBE3 RBE3 Defines the motion at a reference grid point as the weighted average of the motions at a set of other grid points.
Individual weight factors can be created on the independent nodes of RBE3 using the update functionality in the RBE3 panel. See the on-line help for the RBE3 panel for more information.
RJOINT Defines a rigid joint element connecting two coinciding grid points.
RBE2
RROD Defines a rigid pin-ended element connection.
OptiStruct Cards
BMFACE
  • Tria3
  • Quad4
Defines quad or tria faces that are in turn used to define a barrier to limit the total deformation for free-shape design regions.
CAABSF
  • Mass
  • Rod
  • Tria3
  • Quad4
Defines the frequency-dependent fluid acoustic absorber element in coupled fluid-structural analysis.
CBAR Bar2 Defines a simple beam element (BAR) of the structural model.
CBEAM Bar2 Defines a beam element (BEAM) of the structural model.
CBUSH Spring Defines a generalized spring-damper structural element.
CBUSH1D
  • Mass
  • Spring
Defines a one-dimensional spring-damper structural element.
CDAMP1
  • Mass
  • Spring
Represented as a spring element type or as a mass element type (grounded CDAMP1).
CDAMP2
  • Mass
  • Spring
Defines a scalar damper element without reference to a property entry.
Represented as a spring element type or as a mass element type (grounded CDAMP2).
CDAMP3
  • Mass
  • Spring
Represented as a spring element type or as a mass element type (when a coordinate is constrained).
CDAMP4
  • Mass
  • Spring
Defines a scalar damper element that is connected only to scalar points and is without reference to a material or property entry.
CELAS1
  • Mass
  • Spring
Defines a scalar spring element of the structural model.
Represented as a spring element type or as a mass element type (grounded CELAS1).
CELAS2
  • Mass
  • Spring
Defines a scalar spring element of the structural model without reference to a property entry.
Represented as a spring element type or as a mass element type (grounded CELAS2).
Exported in large field format by optistructlf template.
CELAS3
  • Mass
  • Spring
CELAS4
  • Mass
  • Spring
Defines a scalar spring element that is connected only to scalar points without reference to a property entry.
CFAST
  • Mass
  • Rod
Define a fastener with material orientation connecting two shell surfaces.
Represented as a mass or rod element type, depending on fastener configuration.
The type of gap elements (either CGAP or CGAPG) is automatically determined based on whether the element is node-to-node or node-to-elem.
CGAPG
  • Gap
  • Mass
Defines a node-to-obstacle gap element. The obstacle may be an element face or a patch of nodes.
CGASK6 Penta6 Defining the connections of the GASK6 solid gasket element.
CGASK8 Hex8 Defining the connections of the GASK8 solid gasket element.
CGASK12 Penta15 Defining the connections of the GASK12 solid gasket element.
CGASK16 Hex20 Defining the connections of the GASK16 solid gasket element.
CHBDYE Slave1 Defines a surface element for application of thermal boundary condition.
Defined using the Interfacespanel with the CONDUCTION or CONVECTION type.
A second order element with missing mid-side nodes can be defined in OptiStruct. Input data decks containing such elements are read by the translator as a first-order element. A message is written to the OptiStruct.msg file indicating the corresponding element ID.
CMASS1
  • Spring
  • Mass
Represented as a spring element type or as a mass element type (grounded CMASS1).
CMASS2
  • Spring
  • Mass
Represented as a spring element type or as a mass element type (grounded CMASS2).
CMASS3
  • Spring
  • Mass
CMASS4
  • Spring
  • Mass
CMBEAM Bar2 Defines a beam element for multibody dynamics solution sequence without reference to a property entry.
CMBUSH Spring Defines a bushing element without reference to a property entry.
CMBUSHC Spring
CMBUSHE Spring
CMBUSHT Spring
CMSPDP Spring Defines a spring damper element without reference to a property entry for multibody solution sequence.
CMSPDPC Spring Defines a spring damper element without reference to a property entry for multibody solution sequence.
CMSPDPE Spring Defines a spring damper element without reference to a property entry for multibody solution sequence.
CMSPDPT Spring Defines a spring damper element without reference to a property entry for multibody solution sequence.
CONM1 Mass Defines a 6x6 mass matrix at a geometric grid point.
CONM2 Mass Defines a concentrated mass at a grid point of the structural model.
CONV Slave1 Defines a free convection boundary condition for heat transfer analysis through connection to a surface element (CHBDYE card).
Represented as a continuation to CHBDYE slave element card.
CPENTA (6-noded) Penta6 Defines a first order solid element, composed of 3 quadrilateral and 2 triangular faces.
CPENTA (15-noded) Penta15 Defines a second order solid element, composed of 3 quadrilateral and 2 triangular faces.
CPYRA (5-noded) Pyramid5 Defines a first order solid element, composed of 1 quadrilateral and 4 triangular faces.
CPYRA (13-noded) Pyramid13 Defines a second order solid element, composed of 1 quadrilateral and 4 triangular faces.
CQUADR Quad4 Equivalent to CQUAD4. Unlike other Nastran codes, a 6 degree-of-freedom per node formulation is used for all shell elements.
CQUAD4 Quad4 Defines a quadrilateral plate element (QUAD4) of the structural model. This element uses a 6 degree-of-freedom per node formulation.
CQUAD8 Quad8 Defines a curved quadrilateral shell element with eight grid points.
CROD Rod Defines a tension-compression-torsion element (ROD) of the structural model.
CTAXI Tria3 Defines an axisymmetric triangular cross-section ring element for use in linear analysis.
CTETRA (4-noded) Tetra4 Defines a first order solid element, composed of 4 triangular faces.
CTETRA (10-noded) Tetra10 Defines a second order solid element, composed of 4 triangular faces.
CTRIAR Tria3 CTRIAR entry is equivalent to CTRIA3. Unlike other Nastran codes, a 6 degrees-of-freedom per node formulation is used for all shell elements.
CTRIAX6 Tria6 Defines an axisymmetric triangular cross-section ring element for use in Linear Analysis.
CTRIA3 Tria3 Defines a triangular plate element (TRIA3) of the structural model. This element uses a 6 degree-of-freedom per node formulation.
CTRIA6 Tria6 Defines a curved triangular shell element with six grid points.
CTUBE Rod Defines a tension-compression-torsion element (TUBE) of the structural model.
Represented as a spring element type.
CWELD
  • Mass
  • Rod
Represented as a rod element type.
DHEXA8 Hex8
DQUAD4 Quad4
DPENTA6
DTETRAA4 Tetra4
DTRIA3 Tria3
HMSPRING Spring Defines a spring element, which is converted to OptiStruct entities on export, in a manner similar to that explained in Using HM_ELAS.
JOINT Joint Defines a joint.
PLOTEL3
  • Tria
  • Quad4
Defines a three-noded, two-dimensional dummy element for use in plotting.
PLOTEL4
  • Tria
  • Quad4
Defines a four-noded, two-dimensional dummy element for use in plotting.
QBDY1 Flux Defines a uniform heat flux for CHBDYE elements.
RBE2
  • Rigid
  • RigidLink
Defines a rigid body whose independent degrees-of-freedom are specified at a single grid point and whose dependent degrees-of-freedom are specified at an arbitrary number of grid points.
An RBE2 element with one dependent node is represented as a rigid element type, while an element with multiple dependent nodes is represented as a rigid link element type.
RBE3 Rbe3 Defines the motion at a "reference" grid point as the weighted average of the motions at a set of other grid points.
RROD Rod Defines a pin-ended rod that is rigid in extension.
PAM-CRASH Cards
The component of the element refers to a material, which contains the material definition for PAM-CRASH.
FE input reader will not create connectors for Plinks, instead you must use the FE absorb functionality to create connectors from PLINKs.
ASSOCIATE Rigids Defines entities to be converted from deformable to rigid.
BAR / Rod Bar element.
BASE_BODY Rigid Rigid bodies on which the boundary conditions are defined, used in Multibody systems.
BEAM / Bar2 Beam element.
If the orientation vector is defined via vectors, the string VECTOR is displayed in the N3 field, and a zero is written in the exported deck. If the y-direction node is directly specified, its ID is displayed in the N3 field.
BSHEL / Hex8 8-noded brick shell element.
EDG Rod
ELINK / Rod Link element.
The element must be edited in the card previewer to define the connections.
JOINT / Rod Joint element.
The element must be edited in the card previewer to define element orientation.
KJOIN / Rod Kinematic joint element.
LLINK / Rod Link element.
MASS Mass Added mass.
MEMBR /
  • Tria3
  • Quad4
Membrane element.
MTJOIN / FE Joint Multiple node to one node Kinematic joint element.
MTOCO / Rigid Rigid element.
NODCO / Rigid Nodal constraint definition.
This configuration allows you to create nodal constraints via entity sets. The element must be edited in the card previewer. Degrees of freedom are ignored.
OTMCO / RBE3 One node to multiple node constraints.
PLINK / Mass Plink element.
The element must be edited in the card previewer. Mass value is ignored. Use the following templates to handle the welds:
  • find_welds
  • find_master_comps_welds
  • find_slave_comps_welds
  • find_comps_welds
PLINK_VI Rod These elements are created during connector realization to show the actual connections. They are not exported.
RETRA / Mass The element must be edited in the card previewer. Mass value is ignored.
RBODY / Weld Rigid body with 2 nodes.
When created, the default value for rigid body type is 1.
RBODY / Rigid This configuration allows you to create rigid bodies via entity sets. The element must be edited in the card previewer. Degrees of freedom are ignored.
SEG
  • Tria3
  • Quad4
The elements are used in entity selection. With this keyword, only nodes of these elements are output along with SEG keyword.
SENPT / Mass
SHELL / Mass Shell element.
Mass value is ignored. Mass defined with a keyword other than NOD is not supported. The reader creates one mass element for each NOD definition in the MASS card, therefore the exported deck will contain the same number of MASS/cards as many NOD definitions.
SHELL / Tria3 The default behavior for tria3 elements is Coo triangles.
To output standard triangles (N3 = N4).
SHELL / Quad4
SLINK /
  • Tria3
  • Quad4
SLIPR / Mass The element must be edited in the card previewer. Mass value is ignored.
SOLID /
  • Tetra4
  • Pyramid5
  • Penta6
  • Hex8
8-noded brick element.
SPH / Mass
SPRING / Spring Spring element.
SPRGBM / Spring Spring beam element.
TETRA / Tetra10 10-noded tetra element.
Local frame definition.
TETR4 / Tetra4 4-noded tetra element.
TSHEL / Quad4 4-noded thick shell element.
Permas Cards
Card Supported Element Configurations Description
BEAM2 Bar2 2 noded straight general beam
BECOC Bar2 2 noded straight thin-walled tube
BECOP Bar2 2 noded straight thin-walled tube
BECOS Bar2 2 noded straight solid beam
BETAC Bar2 2 noded straight tapered thin-walled tube
BETOP Bar2 2 noded straight thin-walled open beam
CA1ZERF3 Spring Zero Force Element with 1 Node and Three Translational Stiffnesses
CA2ZERF1 Spring Translational Zero Force Element with 2 Nodes
CA2ZERF3 Spring Zero Force Element with 2 Nodes and Three Translational Stiffnesses
CONAX2 Bar2
CONAX3 Bar3
CONA3 Tria3 3 noded triangular surface convection and radiation element.
CONA4 Quad4 4 noded quadrilateral surface convection and radiation element.
CONA6 Tria6 6 noded triangular surface convection and radiation element.
CONA8 Quad8 8 noded quadrilateral surface convection and radiation element.
CONS3 Tria3 3 noded triangular shell surface convection and radiation element.
CONS4 Quad4 4 noded quadrilateral shell surface convection and radiation element.
CONS6 Tria6 6 noded triangular shell surface convection and radiation element.
CONS8 Quad8 8 noded quadrilateral shell surface convection and radiation element.
DAMP1 Spring Translational viscous damper.
DAMP3 Spring Viscous damper for three degrees of freedom.
DAMP6 Spring Viscous damper for six degrees of freedom.
FLA2 Rod 2 noded straight flange (rod).
FLA3 Bar3 3 noded straight flange (rod).
FLHEX8 Hex8 8 noded fluid hexahedron.
FLHEX20 Hex20 20 noded fluid hexahedron.
FLPENT6 Penta6 6 noded fluid pentahedron.
FLPENT15 Penta15 15 noded fluid pentahedron.
FLPYR5 Pyramid5 5 noded fluid pyramid.
FLTET4 Tetra4 4 noded fluid tetrahedron.
FLTET10 Tetra10 10 noded fluid tetrahedron.
FSINTA3 Tria3 3 noded triangular fluid structure interface element.
FSINTA4 Quad4 4 noded quadrilateral fluid structure interface element.
FSINTA6 Tria6 6 noded triangular fluid structure interface element.
FSINTA8 Quad8 8 noded quadrilateral fluid structure interface element.
GKHEX8 Hex8 8 noded solid hexahedron.
GKHEX20 Hex20 20 noded solid hexahedron.
GKPNT6 Penta6 6 noded solid pentahedron.
GKPNT15 Penta15 15 noded solid pentahedron.
HEXE8 Hex8 8 noded solid hexahedron.
HEXE20 Hex20 20 noded solid hexahedron.
LOADA3 Tria3 3 node triangular load carrying membrane element.
LOADA4 Quad4 4 node quadrilateral load carrying membrane element.
LOADA6 Tria6 6 node triangular load carrying membrane element.
LOADA8 Quad8 8 node quadrilateral load carrying membrane element.
MASS3 Mass Point mass.
MASS6 Mass Rigid mass.
$MPC ASSIGN Rigid Dependent nodes are forced to have the same displacement as an independent node. User can specify degrees of freedom for dependent and independent nodes.
$MPC JOIN Rigid Pairwise identical displacements.
$MPC RIGID Rigid Rigid regions.
$MPC SAME Rigid Identical corresponding displacements.
$MPC WLSCON RBE3 Weighted averaged connection.
MPC_IQUAD4 RBE3
Quadrilateral Interpolation Surface
MPC_IQUAD8 RBE3
MPC_IQUAD9 RBE3
MPC_ITRIA3 RBE3
Triangular Interpolation Surface
MPC_ITRIA6 RBE3
NLDAMP Spring Nonlinear translational viscous damper.
NLDAMPR Spring Nonlinear rotational viscous damper.
NLSTIFF Spring Nonlinear translational spring.
NLSTIFFR Spring Nonlinear rotational spring.
PENTA6 Penta6 6 noded solid pentahedron.
PENTA15 Penta15 15 noded solid pentahedron.
PLOTA3 Tria3 3 noded triangular plot element.
PLOTA4 Quad4 4 noded quadrilateral plot element.
PLOTA6 Tria6 6 noded triangular plot element.
PLOTA8 Quad8 8 noded quadrilateral plot element.
PLOTL2 Plot 2 noded straight line plot element.
PLOTL3 Bar3 3 noded straight line plot element.
PYRA5 Pyramid5 5 noded solid pyramid.
QUAD4 Quad4 4 noded quadrilateral shell element.
QUAD4S Quad4
QUAM4 Quad4 4 noded quadrilateral plane membrane element.
QUAM8 Quad8 8 noded quadrilateral plane membrane element
QUAMS4 Quad4 4 noded quadrilateral solid shell element
QUAMS8 Quad8 8 noded quadrilateral solid shell element
QUAX4 Quad4 4 noded quadrilateral axisymmetric solid element
QUAX8 Quad8 8 noded quadrilateral axisymmetric solid element
SHEAR4 Quad4 4 noded quadrilateral plane shear panel element.
SHELL3 Tria3 3 noded triangular shell element for laminates.
SHELL4 Quad4 4 noded quadrilateral shell element for laminates.
SPRINGX1 Spring
SPRINGX2 Spring
SPRINGX3 Spring
SPRING1 Spring Translational spring.
SPRING3 Spring Spring with three translational stiffnesses
SPRING6 Spring Spring with three translational and three rotational stiffnesses.
TET4 Tetra4 4 noded solid tetrahedron.
TET10 Tetra10 10 noded solid tetrahedron.
TRIA3 Tria3 3 noded triangular shell element.
TRIA3K Tria3 3 noded triangular thin shell element.
TRIA3S Tria3
Axisymmetric Solid Element, 3 Noded Triangular Sandwich Shell Element
TRIAX3 Tria3
TRIAX6 Tria6
TRIM3 Tria3 3 noded triangular plane membrane element.
TRIM6 Tria6 6 noded triangular plane membrane element.
TRIMS3 Tria3 3 noded triangular solid shell element
TRIMS6 Tria6 6 noded triangular solid shell element.
X1DAMP3 Mass Scalar viscous damper at one node with three degrees of freedom.
X1DAMP6 Mass Scalar viscous damper at one node with six degrees of freedom.
X1GEN6 Mass General element at one node with six degrees of freedom.
X1MASS3 Mass Scalar mass at two nodes with three degrees of freedom.
X1MASS6 Mass Scalar mass at one node with six degrees of freedom.
X1STIFF3 Mass Scalar spring at one node with three degrees of freedom.
X1STIFF6 Mass Scalar spring at one node with six degrees of freedom.
X2DAMP3 Spring Scalar viscous damper at two nodes with three degrees of freedom.
X2DAMP6 Spring Scalar viscous damper at two nodes with six degrees of freedom.
X2GEN6 Mass General element at two nodes with six degrees of freedom.
X2STIFF3 Spring Scalar spring at two nodes with three degrees of freedom.
X2STIFF6 Spring Scalar spring at two nodes with six degrees of freedom.
Radioss Cards
Note:
  • Shell thickness is included with the connectivity data. The default value is contained in the property set.
  • The time history is provided for the elements.
  • 3D elements are supported.
  • Degenerated 3D solid elements (from Hexa), such as Tetra and Penta, are included with the present 3D elements.
/ADMAS Mass Assign additional non-structural mass to nodes or a group of nodes. Optionally the total additional non-structural mass of a part or a group of parts can be defined (applied to shells and solids only) or a surface mass can be assigned to a surface and Radioss would then compute the added node based mass value using area (volume) - weighted distribution.
/BEAM Bar Describes the beam elements. Two properties (/PROP/TYPE3 (BEAM) and /PROP/TYPE18 (INT_BEAM)) are available for this beam element. The properties describing a beam element are all defined in a local beam coordinate system.
/BRIC20 Hex20 Describes 3D solid elements (20 Node Brick Elements). This quadratic element should be used with the property /PROP/SOLID.
/BRICK
  • Hex8
  • Penta6
  • Pyramid5
  • Tetra4
Defines a hexahedral solid element and thick shell element with 8 nodes.
/CYL_JOINT Rigid Defines cylindrical joints.
/QUAD Quad4 Describes the 2D solid elements. QUAD elements must be defined in the global YZ plane.
/RBE2 Rigid Defines a rigid body whose independent degrees of freedom are specified at a single master node and whose dependent degrees of freedom are specified at an arbitrary number of slave nodes.
/RBE3 RBE3 Defines the motion of a reference (slave) node as the weighted average of the motions of sets of master nodes.
/RBODY Rigid Defines rigid bodies.
/RLINK Rigid Defines a rigid link. The rigid link imposes the same velocity on all the slave nodes in one or more directions.
/SHELL Quad4 Describes input for 4-node shell elements.
/SH3N Tria3 Describes the triangular 3-node shell elements.
/SPHCEL Mass Describes the SPH cells.
/SPRING2N Spring2N Describes the 2-noded spring elements.
/SPRING3N Spring3N Describes the 3-noded spring elements.
/SRPING4N Spring4N Describes the 4-noded spring elements.
/TETRA4 Tetra4 Describes a tetrahedral solid element with 4 nodes.
/TETRA10 Tetra10 Describes a tetrahedral solid element with 10 nodes.
/TRUSS Rod Describes one dimension truss elements, which could be used with property /PROP/TYPE2 (TRUSS). Truss could only carry axial load (like for bar).
/XELEM Xelem Describes the multi-strand elements.
Samcef Cards
AXISYM
  • Bar2
  • Tria3
  • Tria6
  • Quad4
  • Quad8
BUSH Spring
COMP AXISYM
  • Tria3
  • Tria6
  • Quad4
  • Quad8
COMP DEFO PLAN
  • Tria3
  • Tria6
  • Quad4
  • Quad8
COMP MEMB BIDIM
  • Tria3
  • Tria6
  • Quad4
  • Quad8
COMP PLAN GENE
  • Tria3
  • Tria6
  • Quad4
  • Quad8
COMP VOLU
  • Hex8
  • Hex20
  • Penta6
  • Penta15
  • Pyramid5
  • Pyramid13
  • Quad4
  • Quad8
  • Tria3
  • Tria6
COMP VOLU COQUE
  • Hex8
  • Hex20
  • Penta6
  • Penta15
COQU DEFO PLAN
  • Bar2
  • Rod
  • Tria3
  • Tria6
  • Quad4
  • Quad8
DEFO GENE
  • Tria3
  • Tria6
  • Quad4
  • Quad8
DEFO PLAN
  • Bar2
  • Rod
  • Tria3
  • Tria6
  • Quad4
  • Quad8
FLUX THERMIQUE
  • Rod
  • Tria3
  • Quad4
  • Tria6
  • Quad8
FOUR MULT HARM
  • Bar2
  • Tria3
  • Tria6
  • Quad4
  • Quad8
FOURIER
  • Bar2
  • Tria3
  • Tria6
  • Quad4
  • Quad8
HETEROSIS
  • Quad8
  • Tria6
HYBR VOLU
  • Bar2
  • Hex8 Hex20
  • Penta6
  • Penta15 Pyramid5
  • Pyramid13
  • Rod Tetra4
  • Tetra10
  • Tria3 Tria6
  • Quad4
  • Quad8
HYBRID VOLU COQUE
  • Hex8
  • Hex20
  • Penta6
  • Penta15
MEMB AXISYM Bar2
MEMB BIDIM
  • Bar2
  • Rod
  • Tria3
  • Tria6
  • Quad4
  • Quad8
MEMB FLEXION
  • Tria3
  • Tria6
MEMB FOURIER Bar2
MEMB MULT HARM Bar2
MINDLIN
  • Bar2
  • Rod
  • Tria3
  • Quad4
  • Tetra4
  • Pyramid5
  • Penta6
  • Hex8
  • Tria6
  • Quad8
  • Tetra10
  • Pyramid13
  • Penta15
  • Hex20
RBE3 RBE3
SAND VOLU
  • Quad4
  • Quad8
  • Tria3
  • Tria6
SOLID SHELL
  • Hex8
  • Hex20
  • Penta6
  • Penta15
THER AXISYM
  • Bar2
  • Tria3
  • Tria6
  • Quad4
  • Quad8
THER COQU
  • Rod
  • Tria3
  • Quad4
  • Tria6
  • Quad8
THERMIQU
  • Rod
  • Tria3
  • Quad4
  • Tetra4
  • Pyramid5
  • Penta6
  • Penta15
  • Hex8
  • Tria6
  • Quad8
  • Tetra10
  • Pyramid13
  • Penta15
  • Hex20
TUYAU Rod
TUYAU THERMIQUE Rod
VOLU COQUE
  • Hex8
  • Hex20
  • Penta6
  • Penta15
VOLUMIC
  • Bar2
  • Hex8
  • Hex20
  • Rod
  • Tetra4
  • Tetra10
  • Tria3
  • Quad4
  • Tria6
  • Quad8
  • Penta6
  • Penta15
  • Pyramid5
  • Pyramid13
