Multibodies
Multibodies collect and organize ellipsoids, multibody planes, and multibody joints and are typically used in multi-body analysis.
Ellipsoids, multibody planes, and multibody joints can be organized into a multibody using the Organize panel. Every ellipsoid, multibody plane, and multibody joint must be organized into one, and only one, multibody and therefore are mutually exclusive to a multibody. Newly created ellipsoids, multibody planes, and multibody joints are automatically organized into the current multibody.
Operations performed on a multibody collector affect ellipsoids, multibody planes, and multibody joints within the multibody collector. For example, if you delete a multibody collector, the ellipsoids, multibody planes, and multibody joints within the multibody collector are also deleted.
MADYMO
Card Description
BODY.DEFORMABLE Deformable body.
body local system and center of gravity are not used.
Enter the number of MODEs in MODE_LIST and select each applicable MODE element.
Select the DAMPING check box to apply MODAL_DAMP.
BODY.FLEXIBLE_BEAM Flexible beam.
BODY.RIGID This element contains the information necessary to define a unique rigid body: mass, inertia matrix and location of center of gravity.
body local system = ORIENT_INERTIA. If you 'use' the referenced system, no system of a JOINT or BODY should be selected.
center of gravity = CENTRE_OF_GRAVITY
JOINT
SURFACE.CYLINDER Hyper-elliptical cylinder.
