Multibody Joints
MADYMO
Card | Description |
JOINT.BRAC | Card image = BRAC |
JOINT.CYLI | Card image = CYLI D1 and R1 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.FREE | Card image = FREE D1 through D3, R1 through R3 and ORIENT can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. When importing a model containing non-zero values for Q1 through Q7, these values are translated into the values for displacement and rotation; since no values for Q1 through Q7 can be set, no values will be exported. |
JOINT.FREE_BRYANT | Card image = FREE D1 through D3, R1 through R3 and ORIENT can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. When importing a model containing non-zero values for Q1 through Q7, these values are translated into the values for displacement and rotation; since no values for Q1 through Q7 can be set, no values will be exported. |
JOINT.FREE_EULER | Card image = FREE D1 through D3, R1 through R3 and ORIENT can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. When importing a model containing non-zero values for Q1 through Q7, these values are translated into the values for displacement and rotation; since no values for Q1 through Q7 can be set, no values will be exported. |
JOINT.FREE_ROT_DISP | Card image = FREE_BRYANT D1 through D3, R1 through R3 and ORIENT can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. Any JOINT.FREE_ROT_DISP is translated into a JOINT.FREE during import of the model. When importing a model containing non-zero values for Q1 through Q7, these values are translated into the values for displacement and rotation; since no values for Q1 through Q7 can be set, no values will be exported. |
JOINT.PLAN | Card image = PLAN R1, D2 and D3 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.REVO | Card image = REVO R1 can not be changed, because it is defined by the position and orientation of the systems connected by the JOINT. |
JOINT.REVO_TRAN | Card image = REVO_TRAN D1 and R2 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.SPHE | Card image = SPHE R1 through R3 and ORIENT can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. When importing a model containing non-zero values for Q1 through Q4, these values are translated into the values for rotation; since no values for Q1 through Q4 can be set, no values will be exported. |
JOINT.SPHE_BRYANT | Card image = SPHE_BRYANT R1 through R3 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.SPHE_EULER | Card image = SPHE_EULER R1 through R3 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.TRAN | Card image = TRAN D1 can not be changed, because it is defined by the position and orientation of the systems connected by the JOINT. |
JOINT.TRAN_REVO | Card image = TRAN_REVO D1 and R2 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.TRAN_UNIV | Card image = TRAN_UNIV D1, R2 and R3 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.UNIV | Card image = UNIV R1 and R2 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.UNIV_TRAN | Card image = UNIV_TRAN D1, R2 and R3 can not be changed, because they are defined by the position and orientation of the systems connected by the JOINT. |
JOINT.USER | Card image = USER |
