Sensors
Sensor entities define and store sensors typically used in safety analysis.
Sensors do not have a display state in the modeling window.
LS-DYNA Cards
Card | Description |
*DATABASE_CPM_SENSOR | Activates an ASCII file "cpm_sensor". Its input defines sensors' locations based on the positions of some Lagrangian segments. The output gives the history of the velocity, temperature, density, and pressure averaged on the number of particles contained in the sensors. |
*PART_SENSOR | Links part/component to a sensor to activate and deactivate during the
analysis. Note: This is supported as an attribute to an element to maintain its
associativity with element inside HyperMesh.
*SENSOR_CONTROL | Applies sensor result on an entity during run. |
*SENSOR_DEFINE_ELEMENT | Strain gauge type sensor. |
*SENSOR_DEFINE_FORCE | Force transducer type sensor. |
*SENSOR_DEFINE_NODE | Accelerometer type sensor. |
*SENSOR_DEFINE_CALC-MATH | Perform mathematical calculations on sensor values. |
*SENSOR_SWITCH | Compares sensor value with input value and gives a logical signal. |
*SENSOR_SWITCH_CALC-LOGIC | Performs mathematical calculations on the logical signal from sensor logic. |
Nastran
MONDSP1 | Defines a virtual point displacement response at a user-defined reference location (coordinates and coordinates system) as a weighted average of the motions at a set of grid points. |
MONPNT1 | Defines an integrated load monitor point at a point (x,y,z) in a user defined coordinate system. |
MONPNT2 | Element Monitor Output Results Item. |
MONPNT3 | Sums select Grid Point Forces to a user chosen monitor point. |
OptiStruct Cards
MARKER | Defines a marker by associating a grid and a coordinate
system. Note: Bulk Data Entry
PAM-CRASH Cards
SENSO / | Definition of a sensor. Note: Types 2 and 4 are not supported.
SENSOR/ | Definition of a sensor. Note: Types 2 and 4 are not supported.
Radioss Cards
/GAUGE | Defines gauges. Note: Block Format Keyword
/SENSOR | Defines a sensor for geometric nonlinear analysis.
Sensors may be used to activate loads (see NLOAD1). Note: Block Format Keyword
/SENSOR/ACCE | Defines an accelerometer.. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to accelerometer - Type 1. |
/SENSOR/AND | ON if sensors SID1 and SID2 are ON Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to ON as long as S1 AND S2 - Type 4. |
/SENSOR/DIST | Defines pressure gauge. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to Nodal Distance - Type 2. |
/SENSOR/GAUGE | |
/SENSOR/INTER | Defines interface activation and
deactivation. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to Interface Act and Deact - Type 6. |
/SENSOR/NOT | ON if sensor SID1 is OFF. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to On as long as S1 is OFF - Type 8. |
/SENSOR/OR | ON if sensors SID1 or SID2 is ON. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to On as long as S1 OR S2 - Type 5. |
/SENSOR/RBODY | Activation of sensor by Rigid Body force
criteria.
Available in the /SENSOR card image, when the Sensor Type is set to RBody - Type11. |
/SENSOR/RWAL | Activation/Deactivation of sensor by contact with
rigid wall. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to Rigid wall Act and Deact - Type 7. |
/SENSOR/SECT |
Activation of sensor by Section force
criteria. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to Sect - Type12. |
/SENSOR/SENS | Activation with sens_ID1; Deactivation with
sens_ID2. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to Active S1, Deact S2 - Type 3. |
/SENSOR/TIME | Start time. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to Start Time - Type 0. |
/SENSOR/WORK | Activation of sensor by Work criteria. Note: Block Format Keyword
Available in the /SENSOR card image, when the Sensor Type is set to Work - Type 13. |
