Undefined Entities
Undefined entities are entities that will not be written to the solver deck.
The import and export of undefined entities is fully supported for:
  • Components
  • Properties
  • Materials
  • Curves
  • Sets
  • Rigid Walls
  • Cross Sections
  • Accelerometers
  • Boxes
Undefined entities imported from new include files will be organized in the master model.
If an entity is referenced in a solver deck, but is not defined, an undefined entity will be created and assigned the ID of the referenced entity on import. A default card image and a default name will also be assigned to the newly created undefined entity.
Referenced components are created as an undefined entity.
The defined state of an entity is indicated in the Model Browser, Defined column (Property and Material entity views), or in the Entity Editor, Defined Entity field. An active checkbox indicates an entity is defined, whereas an inactive checkbox indicates an entity is undefined.
Undefined entities exhibit the same behaviors as defined entities; they are visible in all relevant browsers and in the Entity Editor. The defined state simply controls the export of the entity.
  • If Defined is inactive, the entity not will be written to the solver deck.
  • If Defined is active, the entity will be written to the solver deck.
The export status of undefined entities cannot be changed. If Defined is inactive, the export status will also be inactive in the Entity State Browser.
Resolve Undefined Entities
Undefined entities can be defined interactively in the session or via the import of a model that contains the referenced entities. This ensures the entity will be written to the solver deck.
  • Define an entity interactively in the session by activating the Defined checkbox in the browser or Entity Editor.
  • Define an entity via the import of a model containing the referenced entities.
    If additional entities residing in the solver deck do not exist, they will be imported as is.
    1. From the menu bar, click File > Import > HyperMesh Model.
    2. In the Import File dialog, open the model containing the referenced entities.
    3. In the File Options dialog, set the relevant option(s) to Keep Incoming Attributes and click OK.
      Figure 3.
Renumber Undefined Entities
The renumbering of undefined entities is restricted to ensure references to entities that reside in external Include files will not be invalidated.
  1. In the Entity Editor, ID field, enter a new number for the undefined entity.
  2. In the dialog that appears, click Yes to execute the renumbering operation.
    Figure 4.
