Edge Fillets
Use the Fillets tool to create edge fillets between two free surface edges.
  1. From the Geometry ribbon, click the Fillets tool.
  2. Left-click on the surface or surface edge to select. If you select a surface, all edges connected to the surface will be selected.
  3. In the microdialog, type a positive radius value for the fillet.
    A preview of the fillet displays.
  4. If you are satisfied with the resulting fillet, click Fillet All.
