Split with Planes
Use the Split: Planes tool to split lines, surfaces, or solids.
- Select a splitting plane using reference entities or features that are disconnected from the geometry you want to split, including points in space.
- You can modify your surface selection after selecting a splitting plane. Split preview lines will update appropriately.
- Use snap points to snap the splitting plane to predefined points on lines and surfaces, such as middle and end points. Clicking a snap point automatically selects attached surfaces/solids.
Split: Planes Tool
An overview of the Split: Planes tool.
Figure 3.
Use the Split: Planes tool to split lines, surfaces, or solids using a plane or a surface.
- Access
- Go to .
Options
- Fill cut loops
- Create a new surface if the edges being split form a closed loop.
- Extend trimmer
- Extend the trim beyond the trimmer boundaries.
