Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can
be modeled as a simple line for FEA purposes.
The vector formed by beam nodes N1 and N2 is compared to the reference vector. If the angle between the two vectors
is below the angle tolerance, directions are considered matching. Matching elements will have N1 and N2 ordered along
the positive direction of the reference vector.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts
or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell
meshing.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Reorder the N1 to N2 sequence of 1D element nodes.
The Align tool allows you to reorder element nodes using a vector or a system
axis. Figure 1.
From the guide bar, click the Elements selector.
Select elements to reorder N1 and N2 in ascending order along one or more axis
if elements are aligned with vectors in a given angle tolerance. This is useful
when the beam section shape if not symmetric.
Reference Direction
The vector formed by beam nodes N1 and N2 is compared to the reference vector. If the angle between the two vectors is below the angle tolerance, directions are considered matching. Matching elements will have N1 and N2 ordered along the positive direction of the reference vector.
