Detach Elements
Use the Detach tool to detach elements from the surrounding structure. You can detach elements from a portion of your model so that it can be translated or moved, or you can offset the new nodes by a specified value. You can also use this panel to detach and remove elements from your model.
For more information on detaching elements, see the Detach Panel topic.
