Edit Edge Density and Element Size
Use the General 2D Mesh: Density tool to edit element density and size along surface edges.
General 2D Mesh: Density Tool
An overview of theGeneral 2D Mesh: Density tool.
- Access
- Go to .
Options
- Auto update
- Select auto/manually remesh option.
- Element size
- Change the average element size.
- Link opposite edges
- Select if an aspect ratio should be used to link the default mesh density on opposing edges of rectangular surfaces.
- Aspect ratio
- Change the maximum aspect ratio to allow between large and small edge sizes of linked edges.
Keyboard Shortcuts and Mouse Controls
To do this | Press |
Increase edge value | Ctrl + Left Mouse Click |
Decrease edge value | Ctrl + Right Mouse Click |
Scroll edge value | Ctrl + Middle Mouse Scroll |
Edit value in microdialog | Middle Mouse Scroll |
