Pins Tool
Use the Pins tool to edit node A and node B.
- Select the appropriate element(s) in the model.
- Click the Pins tool.
- Move the node A and node B microdialogs so that they are both visible. The node A microdialog initially covers the node B microdialog.
- On the node A microdialog, decide whether you want to translate or rotate the selected element(s).
- Click the appropriate translate or rotate button depending on which axis you would like to affect.
