Property Selection (Optional)
In this optional step, you can select elements that can be assigned properties or a beam section.
If an element configuration type is selected, the list of properties will be filtered based on the selected type. For example, a Config Bar2 with type CBAR will keep only PBAR and PBARL properties, while a type CBEAM will keep only PBEAM and PBEAML.
If a beam section is selected, the property will be automatically created based on the element configuration type and will be assigned to the elements that are created.
