Properties define various physical and mathematical characteristics of parts such as
sheet metal, extruded, and simplified representations of parts. The assignment and
unassignment of properties have a specific set of rules based on the solver interface being
used.
Solver interfaces allowing for the indirect (components) and direct (elements)
assignment:
- OptiStruct
- Nastran
- Abaqus
- Samcef
- EXODUS
Note: If a property is directly assigned to an element, that property takes
priority over any indirect property assigned to the component that the element
may be contained within.
Solver interfaces allowing for only indirect (component) assignment:
- LS-DYNA
- Radioss
- ANSYS
- Permas
- Marc
- Feko
From the Model ribbon, click the Assign
Properties tool.
- Optional:
On the guide bar, click
to enable selection filtering.
Assign or unassign properties.
