Sync Library Revisions
Sync the in-session version of the library with the latest available version in the Subsystem Library.
If the version available in the current session is out of sync with the library revision, use Sync to update the session version with the Subsystem Library version. Before you can sync library revisions, you must be connected to the library. Refer to Register and Connect Libraries.
