Modeling Window
The modeling window is where your model is displayed.
The modeling window occupies the middle portion of the application.
You can select entities and manipulate the view of the model in the modeling window.
The global axes, located in the bottom, left of the modeling window, indicates the location of the displayed model.
You can adjust the display theme and behavior of the modeling window from the Preferences dialog.
