Configuration Options
Configure the display and behavior of the Solver Browser.
Local Options
Open the Browser Configuration dialog by right-clicking in the Solver Browser and selecting Configure Browser from the context menu.
- Delete association
- Open the Delete component(s) and unique associations dialog when Delete Advanced is selected from the context menu. When this box is checked off, the Delete component(s) and unique associations dialog does not open when Delete Advanced is selected from the context menu, and the entities uniquely related to the selected component are automatically deleted.
- Hide attached
- Mask the attached elements in the modeling window when you hide the following entities: loads, load collectors, load steps, groups and contact surfaces. This can be observed if the elements are currently displayed. This will not change the display state to off; thus, that the local display icon will not be dimmed.
- Show/hide/isolate Include files with References
- Show, hide, isolate the contents of an Include file when you Show/Hide/Isolate the Include file. If you turn this option off, Show/Hide/Isolate will only affect the components and other HM entities that have graphics (vectors, systems, plies, laminates, loads) in the Model Browser, Solver Browser, and ID Manger Include files.
- Show/Isolate/Isolate Only attached
- View the attached elements in the modeling window when you Show/Isolate/Isolate Only the following entities: loads, load collectors, load steps, groups and contact surfaces. This can be observed if the elements are currently masked or the display state of the component's elements is turned off. This will also turn on the local display icon.
- Maximum number of items
- Change the maximum number of items to display in the browser.
- Show empty folders
- Display every entity type supported by the solver in the browser.
Browser Attributes
Right-click on a column heading in the browser to configure
the displayed attributes.
- ID
- Unique entity ID
- Color
- Entity color
- Include
- ID of Include file the entity is stored within
- FE Style
- Lists the element style applied to each entity. Click the icon to change the style.
