Altair Driver File
The Altair Driver File event allows you to run your own Altair Driver File and use this file in the event.
You can begin with an existing event and modify it, or you can write your own event file. Additional information on writing the events can be found in the online help. A graphical user interface to populate critical items in the events is not currently supported.
See the Altair Scripted Driver topic to learn more about Altair Driver.
