Assembly Wizard Dialog
In MotionView, models are assembled from libraries of pre-defined systems using the Assembly Wizard, located on the Model menu. The Assembly Wizard dialog guides you through the assembly process, ensuring that your selections are compatible.
![](../../images/post_processing/assembly_wizard_model_type.png)
Figure 1. Assembly Wizard Dialog
- Next
- Moves to the next panel.
- Back
- Returns to the previous panel for review or edit.
- Cancel
- Closes the Assembly Wizard.
- Reset Selection
- Resets the assembly wizard.
- Message Log...
- Displays the message log at the bottom of the dialog.
- Clear
- Clears the message log.Note: This button is only activate if the message log is displayed.
Model Type
Driveline Configuration
![](../../images/post_processing/assembly_wizard_driveline_config.png)
Figure 3.
Primary Systems
![](../../images/post_processing/assembly_wizard_primary_systems.png)
Figure 4.
Steering Subsystems
![](../../images/post_processing/assembly_wizard_steering_subsystems.png)
Figure 5.
Springs, Dampers, and Stabars
![](../../images/post_processing/assembly_wizard_springs_dampers_stabars.png)
Figure 6.
Jounce/Rebound Bumpers
![](../../images/post_processing/assembly_wizard_jounce_rebound_bumpers.png)
Figure 7.
Label and Varname Specifications
![](../../images/post_processing/assembly_wizard_label_varname.png)
Figure 8.
Once you have made your selections, the Assembly Wizard retrieves the systems from the libraries and connects them in a hierarchical structure.
The attachments specified during the assembly process can be modified using the Attachment Wizard dialog.
