Constant Radius
A Constant radius event simulates a vehicle driving in a circular path.
The Constant radius event maintains a constant turn radius and varies the vehicle velocity to produce increasing amounts of lateral acceleration. Steering and torque controllers maintain the path and the speed of the vehicle through the event. A plot template is available to plot the results. The Constant radius event is used to characterize the roll and understeer characteristics of a vehicle.
Parameter | Description |
Units | Length unit selection (Model, m, ft). Velocity unit selection (Model, m/s, km/h, mph). Acceleration unit selection (Model, m/s2, gās). |
Radius | The radius of the circle that the vehicle CG will follow during the constant radius portion of the event. |
Initial straight | Vehicle is driven straight this distance, to attain steady state. |
Initial velocity | Initial vehicle velocity. |
Final velocity | Final velocity desired in the simulation. |
Initial lateral acceleration | Estimated initial lateral acceleration, calculated using the initial speed and the turn radius. |
Final lateral acceleration | Estimated final lateral acceleration, calculated using the initial speed and the turn radius. |
Turn direction | Direction the vehicle turns during the event (as seen by the driver). |
Transient time | Time duration for which vehicle accelerates/decelerates after achieving steady state. |
Look ahead time | Look ahead time, used by the Driver feedforward steering model. |
Time in circular track | The time spent in the circular track. |
Prediction step size | Maximum step size, used by the Driver feedforward steering model. |
Print interval | Time interval of data output to the plot file (.plt) and graphics file (.h3d). |
References
ISO +4138-2004 - Passenger cars ā Steady-state circular driving behavior ā Open-loop test methods.
