Graphic Entity Attributes
Model files are composed of many different parts, or entities. MotionView allows you to change the display attributes of each entity in a graphic. Visual properties such as shading, color, and mesh lines can be assigned using the Graphic Entity Attributes panel.
![](../../images/icons/palette-24.png)
![](../../images/post_processing/graphics_entity_attributes_panel.png)
Figure 1. Graphic Entity Attributes Panel
