MF-SWIFT/MF-Tyre Modeling
- MF-SWIFT Tire models are suitable for vehicle ride comfort studies, durability, and vibration analysis. With MF-SWIFT it is possible to capture tire dynamic behavior up to 120Hz. The model contains a representation of the tire carcass and sidewalls as a rigid ring with six degrees of freedom. A sophisticated model of contact patch is also included, which is able to simulate effects of partial sliding and tread element compliance. The MF-SWIFT Tire model includes a Magic Formula steady state model, making it suitable also for use in vehicle handling events.
- MF-Motorcycle Tire models can be used to accurately capture tire dynamics at high level of camber angles (up to 60 degrees).
Click on the links below to learn more about the implementation of TNO Tire models and their usage in MotionView and MotionSolve:
