Wheel Center Rotational Stiffnesses
Branch ID: 60
Request Number: 80000060
Table 1.
.plt File .mr, .abf File Component Unit Comment
F1 RESULT(1) Not Used Not Used Not Used
F2 RESULT(2) Left Wheel Center XX Stiffness N-m/deg The left wheel center single wheel rotational stiffness about the global longitudinal axis or:
1/C(4,4)/rtod/1000
F3 RESULT(3) Left Wheel Center YY Stiffness N-m/deg The left wheel center single wheel rotational stiffness about the global lateral axis or:
1/C(5,5)/rtod/1000
F4 RESULT(4) Left Wheel Center ZZ Stiffness N-m/deg The left wheel center single wheel rotational stiffness about the global vertical axis or:
1/C(6,6)/rtod/1000
F5 RESULT(5) Not Used Not Used Not Used
F6 RESULT(6) Right Wheel Center XX Stiffness N-m/deg The right wheel center single wheel rotational stiffness about the global longitudinal axis or:
1/C(10,10)/rtod/1000
F7 RESULT(7) Right Wheel Center YY Stiffness N-m/deg The right wheel center single wheel rotational stiffness about the global lateral axis or:
1/C(11,11)/rtod/1000
F8 RESULT(8) Right Wheel Center ZZ Stiffness N-m/deg The right wheel center single wheel rotational stiffness about the global vertical axis or:
1/C(12,12)/rtod/1000
