Building a Test Rig Model using the Assembly Wizard
In MotionView, models are
assembled from libraries of pre-defined systems using the Assembly Wizard. The Assembly
Wizard dialog guides you through the assembly process, ensuring that your selections are
compatible.
Start MotionView from the installation folder of
Altair HyperWorks.
The MotionView window is displayed. Figure 1.
Click Model → Assembly Wizard.
The Assembly Wizard – Model Type window opens. Figure 3.
Select the Test Rig radio button and click
Next.
The Assembly wizard – Test Rig Options window opens. Figure 4.
Select the Component Test Rig option and click
Next.
The Primary system for the test rig model window opens. Figure 5.
Select the required auto entity from the drop-down list and click
Next.
Now you have selected all the required systems for the model, click
Finish button to complete the assembly process and
exit the Assembly Wizard.
Figure 6.
Note: Click Attachments button to if you wish to proceed
with the Attachment Wizard.
The AutoSpring test rig model build through the Assembly Wizard is displayed in
the graphics area.
Figure 7. AutoSpring Test Rig
The systems you have selected to build the model is displayed in the Project Browser.
