Throttle-off Turn-in
A Throttle-off turn-in event simulates the dynamics of a vehicle driving a constant radius turn at steady state, the reaction of the vehicle due to a sudden removal of drive torque during the cornering event in which the steer is ramped up.
The event includes a short straight section to allow the vehicle to come to steady state, the constant radius circle, and throttle removal. The event is designed to simulate a highway exit ramp maneuver. Appropriate vehicle and tire output requests are included. A plot template is available to plot the results.
Parameter | Description |
Units | Length unit selection (Model, m, ft) Velocity unit selection (Model, m/s, km/h, mph) Acceleration unit selection (Model, m/s2, g’s) |
Radius | The radius of the circle that the vehicle CG will follow during the constant radius portion of the event. |
Initial straight | The distance the vehicle is driven straight and corners in a given radius to attain the steady state. |
Velocity | The velocity of the vehicle during the event. |
Initial lateral acceleration | Estimated initial lateral acceleration, calculated using the velocity and the turn radius. |
Turn direction | Direction the vehicle turns during the event (as seen by the driver). |
Throttle step duration | Time duration the throttle controller takes to completely remove the drive torque. |
Steer ramp rate | Rate at which steering is ramped up after the drive torque goes to zero. |
Transient time | Time duration for which the vehicle makes the drive torque zero and ramps up the steering. |
Look ahead time | Look ahead time, used by the Driver Feedforward steering model. |
Prediction step size | Maximum step size, used by the Driver Feedforward steering model. |
Print interval | Time interval of data output to the plot file (.plt) and graphics file (.h3d). |
Reference
ISO 9816-2006 Passenger cars — Power-off reaction of a vehicle in a turn.
