Used when a structure is subjected to a non-deterministic, continuous
excitation.
Cases likely to involve non-deterministic loads are those linked to conditions such as turbulence
on an airplane structure, road surface imperfections on a car structure, noise loads
on a given structure, and so forth.
Random Response Analysis requires as input, the complex frequency responses from
Frequency Response Analysis and Power Spectral Density Functions of the
non-deterministic Excitation Source(s). The Complex Frequency Responses can be
generated by Direct or Modal Frequency Response Analysis.
Different Load Cases (a and b)
If Hxa(f) and
Hxb(f)
are the complex frequency responses (displacement, velocity or
acceleration) of the xth degree of freedom, due to Frequency
Response Analysis load cases a and b respectively, the power spectral density of the
response of the xth degree of freedom,Sxo(f) is:(1)
Sxo(f)=Hxa(f)Sab(f)Hxb(f)
Where, Sab(f) is the cross power spectral density of two
(different, a≠b) sources, where the individual source a is the excited load case and b is the applied load case. This value can possibly be
a complex number.
Same Load Case (a)
If Sa(f) is the spectral density of the individual source
(load case a), the power spectral density of the response of xth degree of freedom due to the load case a will be:(2)
Sxo(f)=|Hxa(f)|2Sa(f)
Combination of Different (a,b) and Same (a,a) Load Cases in a Single Random Response
Analysis
If there is a combination of load cases for Random Response Analysis, the total power spectral density of the response will be the summation of the power spectral density of responses due to all individual (same) load cases as well as all cross (different) load cases.
Auto-correlation Function
Consider a time-varying quantity, y. The auto-correlation function Ay(τ) of a time-dependent function y(t) can be defined by:(3)
Ay(τ)=limT→∞+T/2∫−T/2y(t)y(t+τ)dt
Where,
τ
The time lag for Auto-correlation
The variance σ2(y) of the time-dependent function y(t) is equal to Ay(0). The variance σ2(y) can be expressed as a function of power spectral
density Sy(f), as:(4)
Ay(0)=σ2(y)=∞∫−∞Sy(f)df
The root mean square value (yRMS) of the time-dependent quantity y(t) can also be written by:(5)
yRMS=√¯¯¯¯¯¯y(t)2+σ2(y)
If the mean (¯¯¯¯¯¯y(t)) of the function is equal to 0, then the RMS value
is the square root of the variance. Since the variance is also equal to Ay(0), the RMS value can be written as:(6)
yRMS=
⎷∞∫−∞Sy(f)df
RMS of the Response Power Spectral Densities for degree of freedom "x"
The RMS values at each excitation frequency is defined as the cumulative sum of the
area under the Power Spectral Density function up to the specified frequency. Based
on the equation for yRMS obtained in the previous section, the RMS value of a
response for a particular degree of freedom x is calculated in the range of excitation
frequencies, [f1, fn] as:(7)
(Sx(f))RMS=
⎷fn∫f1Sx(f)df
In HyperView, the RMS values are displayed for a Random
Response Analysis in a drop-down menu with excitation frequencies. Each selection
within this menu displays the sum of cumulative RMS values for the particular
response at all previous excitation frequencies (which is the area under the
response curve up to the loading frequency of interest). The RMS over
frequencies option can be selected to obtain the RMS value of the
response in the entire frequency range. Figure 1.
Auto-correlation Function Output for degree of freedom "x"
The RANDT1 Bulk Data Entry can be used to specify the lag time
(τ) used in the calculation of the Auto-correlation function
for each response for a particular degree of freedom, x.
The auto-correlation function and the power spectral density are Fourier transforms
of each other. Therefore, the auto-correlation function of a response Sx(f) can be described as:(8)
Ax(τ)=2fn∫0Sx(f)exp(i2πf)df
The Auto-correlation Function is calculated for each time lag value in the specified
RANDT1 set over the entire frequency range [0, fn].
Number of Positive Zero Crossing
Random non-deterministic excitation loading on a structure can lead to fatigue
failure. The number of fatigue cycles of random vibration is evaluated by
multiplying the vibration duration and another parameter called maximum number
of positive zero crossing. The maximum number of positive zero crossing
is calculated as:(9)
If XYPLOT, XYPEAK or
XYPUNCH, output requests are used, the root mean square value and
the maximum number of positive crossing calculated at each excitation frequency will
be exported to the *.peak file.
