Loading [MathJax]/jax/output/CommonHTML/jax.js
CELAS4F
Bulk Data Entry Defines a scalar spring element that is connected only to scalar points without reference to a property entry. The corresponding properties on this entry are not affected by translational and rotational stiffness limits specified using PARAM,ELASSTIF.
CELAS4F EID K S1 S2     GE S
CELAS4F 42 6.2-3 2
EID Unique element identification number.
No default (Integer > 0)
K Stiffness of the scalar spring.
No default (Real)
S1, S2 Scalar point identification numbers.
S1 or S2, but not both, may be blank or zero indicating a constrained coordinate.
Default = 0 (Integer ≥ 0; S1S2)
GE Damping coefficient.
GE is ignored in transient analysis, if PARAM, W4 is not specified.
Default = 0.0 (Real)
S Stress coefficient.
  1. This single entry completely defines the element since no material or geometric properties are required.
  2. Only one scalar spring element may be defined on a single entry.
  3. A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
  4. The element force of a spring is calculated from the equation: (1)
    F = k * (u1 - u2)
    Where, k is the stiffness coefficient for the scalar element and u1 is the displacement of the first degree-of-freedom listed on the CELAS4 entry.
    Element stresses are calculated from the equation:(2)
    s=S*f
    Where, S is the stress coefficient as defined above.
  5. This card is represented as a spring or mass element in HyperMesh.
