CQUAD4
Bulk Data Entry Defines a quadrilateral plate element (QUAD4) of the structural model. This element uses a 6 degree-of-freedom per node formulation.
CQUAD4 | EID | PID | G1 | G2 | G3 | G4 | Theta or MCID | ZOFFS | |
T1 | T2 | T3 | T4 |
CQUAD4 | 111 | 203 | 31 | 74 | 75 | 32 |
EID | Unique element identification
number. No default (Integer > 0) |
PID | A
PSHELL,
PCOMP,
PCOMPP or
PHFSHL
property entry identification number.
Default = EID (Integer > 0 or <String>) |
G1, G2, G3, G4 | Grid
point identification numbers of connection
points. No default (Integers > 0, all unique) |
Theta | Material orientation angle in
degrees. Default = 0.0 (Real) |
MCID | Material coordinate system
identification number. The x-axis of this coordinate system is projected onto
the element to define the x-axis of the material coordinate system.
Default is Theta = 0.0 (Integer > 0) |
ZOFFS | Offset from the plane defined by element grid
points to the shell reference plane. 10 Overrides the ZOFFS specified on the PSHELL entry. Default = 0.0 (Real, Character Input = TOP/BOTTOM, or blank) |
Ti | Thickness of the element at the grid points.
Overrides the thickness specified on the
PSHELL entry. The values of
Ti specified here will be
directly used in the
solution. PARAM,SHELLTI,NO can be used to switch to using the average value of T1, T2, T3, and T4 as the shell thickness. (Real ≥ 0.0 or blank) |
- Grid points G1 through G4 must be ordered consecutively around the perimeter of the element.
- All of the interior angles must be less than 180 degrees.
- The
elemental coordinate system is a bisection
definition as depicted in Figure 1:
Figure 1. Elemental Coordinate System - For H3D and OUTPUT2 output formats, stresses and strains are always output in the elemental system.
- For
HM, PUNCH and OPTI output formats, stresses and
strains are output by default in the material
coordinate system. PARAM, OMID
can be set to NO to output
results in the elemental system. For elements with
blank
Theta/MCID,
THETA = 0.0 is assumed, and the
material coordinate system is aligned with side
G1-G2 of the
shell element. For elements with assigned
THETA, the material x-axis is
rotated from side
G1-G2 by
angle THETA. For elements with
MCID, the material system is
constructed by projecting the
MCID onto the plane of the
element.
Figure 2. Orientation when Theta (real value) is Entered in 8th Field
Figure 3. Orientation when MCID (integer value) is Entered in 8th Field - If any of the Ti fields are blank, the thickness specified on the PSHELL data will be used for that node's thickness. If 0.0 is specified for Ti, then the thickness at that node is zero.
- If the property referenced by PID is selected as a region for free-size or size optimization, then any Ti values defined here are ignored. If you input Ti for elements in the design space for Topology or Free-Size (Parameter) optimization, the run will error out.
- If Ti is present, the PID cannot reference PCOMP or PCOMPP data.
The shell reference plane can be offset from the plane defined by element nodes by means of ZOFFS. In this case all other information, such as material matrices or fiber locations for the calculation of stresses, is given relative to the offset reference plane. Similarly, shell results, such as shell element forces, are output on the offset reference plane.
ZOFFS can be input in two different formats:- Real
- A positive or a negative value of ZOFFS is specified in this format. A positive value of ZOFFS implies that the reference plane of each shell element is offset a distance of ZOFFS along the positive z-axis of its element coordinate system.
- Surface
- This format allows you to select either "Top" or "Bottom" option to specify the offset value.
Note: When ZOFFS is used, both MID1 and MID2 must be specified on the PSHELL entry referenced by this element (otherwise, singular matrices would result).Offset is applied to all element matrices (stiffness, mass, and geometric stiffness), and to respective element loads (such as gravity). Hence, ZOFFS can be used in all types of analysis and optimization. Automatic offset control is available in composite free-size and sizing (parameter) optimization where the specified offset values are automatically updated based on thickness changes.Note: For first order shell elements (CQUAD4 and CTRIA3), the offset operation does not correct for secondary effects, such as change of shell area when offset is applied on curved surfaces. Therefore, the value of ZOFFS should be kept within a reasonable percentage (10% - 15%) of the local radius of curvature.However, while offset is correctly applied in geometric stiffness matrix and hence can be used in linear buckling analysis, caution is advised in interpreting the results. Without offset, a typical simple structure will bifurcate and loose stability "instantly" at the critical load. With offset, though, the loss of stability is gradual and asymptotically reaches a limit load.
Figure 6. - PHFSHL properties are only valid with an @HYPERFORM statement in the first line of the input file.
- The CQUAD4 element utilizes 5 integration points. The reason for utilizing more than 4 integration points is due to the usage of bubble shape functions, which increases the order of approximation beyond that of a standard linear shell. Their actual locations and weights are adjusted based on the element configuration.
- For more information, refer to Two-dimensional Shell Elements in the User Guide.
- String based labels allow for easier visual identification of properties, when being referenced by the elements cards. For more details, refer to String Label Based Input File in the Bulk Data Input File.
- This card is represented as a quad4 element in HyperMesh.
