CSHEAR
Bulk Data Entry Defines a shear panel element.
CSHEAR | EID | PID | G1 | G2 | G3 | G4 |
CSHEAR | 111 | 67 | 89 | 123 | 124 | 56 |
EID | Unique element
identification number. (Integer > 0) |
PID | A PSHEAR property entry
identification number. (Integer > 0; If blank, defaults to EID) |
G1, G2, G3, G4 | Grid point identification
numbers of connection points. Grid points G1 through G4 must be ordered consecutively around the perimeter of the element. (Integer > 0; all unique) |
- All interior angles must be less than 180
degrees.
Figure 1. CSHEAR Definition
Figure 2. CSHEAR Element Corner Forces and Shear Flows - Shear panel elements are ignored in heat transfer analysis.
- This card is represented as a quad4 element in HyperMesh.
