CTPSTN
Bulk Data Entry Defines a plane strain triangular element in x-z or x-y plane.
CTPSTN EID PID G1 G2 G3 G4 G5 G6
  THETA
CTPSTN 111 2 31 74 75 32 51 52
  15.0
Definition
EID Unique element identification number.
No default (Integer > 0)
PID A PPLANE entry identification number.
Default = EID (Integer > 0)
G1, G2, G3 Identification numbers of connected corner grid points.
These fields are mandatory.
No default (Integers > 0, all unique)
G4, G5, G6 Identification numbers of connected edge grid points.
Default = blank (Integers > 0 or blank)
THETA Material orientation angle in degrees.
Default = 0.0 (Real)
  1. Element identification numbers must be unique with respect to all other element identification numbers.
  2. The Grid ordering of G1 through G6 are defined as:
    Figure 1. CTPSTN Definition
  3. The continuation line is optional.
  4. If the PPLANE entry referenced in field 3 references a MAT3 entry, material properties and stresses are always given in the xm-zm coordinate system shown in Figure 1.
  5. Plane strain analysis defined in x-y plane is supported, i.e. the axis labels of ā€œzā€ above can be replaced by ā€œyā€.
  6. A concentrated load (e.g. a load specified by a FORCE entry) at a grid Gi of this element is defined to distribute along the thickness, T, of the element. For example, in order to apply a load of 200 N/m to a node Gi with the element thickness being 5.0m, the amount to be specified on the load entry should be:(1)
    (200N/m)*5.0m=1000N(200N/m)*5.0m=1000N
    The default thickness of 1.0 is used, if T is not specified on the PPLANE entry.
  7. Plane strain elements are supported in linear analysis, small and large displacement nonlinear static analyses. They are currently not supported for large displacement inertia relief analysis.
