DLINK
Bulk Data Entry Defines a link between one design variable and one or more other design variables.
DLINK | ID | DDVID | C0 | CMULT | IDV1 | C1 | IDV2 | C2 | |
IDV3 | C3 | etc. |
DLINK | 55 | 3 | 0.2 | 0.45 | 5 | 2.0 | 10 | 5.5 | |
15 | -3.0 |
ID | Unique
DLINK identification number. (Integer > 0) |
DDVID | Dependent Design Variable
C0 | Constant. Default = 0.0 (Real) |
CMULT | Constant
multiplier. Default = 1.0 (Real) |
IDVi | Independent Design
Variable identification number. Can occur on the same
DLINK entry only once. (Integer > 0) |
Ci | Coefficient multiplier for
IDVi. (Real) |
- DLINK defines the
relationship.
(1) DDVID=C0+CMULT∑iCi*IDViDDVID=C0+CMULT∑iCi*IDViThis capability allows physical and non-physical design variables to be related such as shell thickness and interpolating functions.
- CMULT and Ci can be used together to provide a simple means of scaling.
- This card is represented as an optimization design variable link in HyperMesh.
