EKE
I/O Options and Subcase Information Entry The EKE command can be used in the I/O Options or Subcase Information sections to request kinetic energy and kinetic energy density output for all subcases or individual subcases, respectively.
EKE (format_list, type, dmig, peakoutput, group) = option
Argument | Options | Description |
format | <HM, H3D, PUNCH, OP2, PLOT, blank> |
type | <AVERAGE, AMPLITUDE, PEAK> |
dmig | <DMIG, NODMIG> |
peakoutput | <PEAKOUT> Default = blank |
If PEAKOUT is present, only the filtered frequencies from the PEAKOUT card will be considered for this output. |
group | <PROP,
COMP, SET,
OPROP, OCOMP,
OSET> Default = blank |
option | <YES, ALL,
NO, NONE,
SID> Default = ALL |
- When an EKE command is not present, element kinetic energy and kinetic energy density is not output.
- Initial thermal strain is included in the calculation of kinetic energy and kinetic energy density.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
- For optimization, the frequency of output to a given format is controlled by the I/O option OUTPUT.
- type only applies to Frequency Response Analysis.
- The three ways to calculate the Element Kinetic Energy
in Frequency Response Analysis are:
- Output Type
- Formula
- Average
- E0=14(vTrMEvr+vTiMEvi)
- Amplitude
- Ea=14√(vTrMEvr−vTiMEvi)2+(2vTrMEvi)2
- Peak
- Epeak=E0+Ea
Where,- E
- Corresponding Element Energy
- vr
- Real part of Displacement
- vi
- Imaginary part of Displacement
- ME
- Element Mass Matrix
- format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
- The group argument is only supported only
for Static, Eigenvalue, Frequency response, and Transient analysis in H3D and
PCH format. Group Damping Energy and Group Damping Energy Density are available
under the Element Damping Energy results type in the H3D file. In the Punch
file, the Property/Component ID’s and the corresponding Damping Energy and
Damping Energy Density are available.
If SET/OSET is requested a SID of Boolean set with operator OR is expected in the field option. Element SETs referenced when using this option should have the OPERATOR field set to OR. Regular element sets without Boolean OR are not allowed. SET/OSET is currently only supported for H3D and PUNCH formats.
- Rotor Energy output for Direct/Modal Complex Eigenvalue Analysis (with ASYNC, SYNC, and multiple rotors) is available in the <filename>.rengy file when ESE or EKE output requests are present in the model. The output printed to the .rengy file is calculated as a percentage of the ratio of rotor energy to the requested energy output of elements. It is recommended that you request energy output for ALL elements so that the rotor energy percentage printed in the .rengy file is meaningful.
