FORCE / ELFORCE
I/O Options and Subcase Information Entry Used to request structural element force output and elemental fluid particle velocity output for all subcases or individual subcases, respectively.
FORCE (sorting, format_list, form, type, location, random, peakoutput, modal,statistics) = option
Argument | Options | Description |
sorting | <SORT1, SORT2> | This argument only applies to the PUNCH format (.pch file) or the
OUTPUT2 format (.op2 file file) output for normal modes,
frequency response, and transient subcases. It will be ignored
without warning if used elsewhere.
format | <HM, H3D, OPTI, PUNCH, OP2, PLOT, HDF5, blank> |
form | <COMPLEX, REAL,
IMAG, PHASE,
BOTH> Default (HM only) = COMPLEX Default (all other formats) = REAL |
type | <TENSOR, DIRECT> | |
location | <CENTER, CUBIC, SGAGE, CORNER, BILIN> |
random | <PSDF,
RMS, PSDFC> No default |
peakout | <PEAKOUT> Default = blank |
If PEAKOUT is present, only the filtered frequencies from the PEAKOUT card will be considered for this output. |
modal | <MODAL> Default = blank |
statistics | <STATIS, OSTATIS, or blank> | Element force statistics over time in a Transient Analysis are
controlled by this option. 14
option | <YES, ALL,
NO, NONE,
SID> Default = ALL |
- If neither FORCE nor ELFORCE commands are present, then Force results or Fluid Particle Velocity results are not output. Fluid Particle Velocity results are currently only supported for H3D, OP2, and PUNCH formats.
- FORCE results are available for
ELAS (CELAS1, CELAS2,
CELAS3, CELAS4), ROD
(CROD), BAR (CBAR,
CBEAM), BUSH (CBUSH), PLATE
(CQUAD, CTRIA), GAP
(CGAP), FASTENER (CFAST)*, VISCOUS
DAMPER (CVISC), SCALAR DAMPER (CDAMP1,
CDAMP2, CDAMP3,
CDAMP4) and WELD (CWELD)
elements.
*CFAST elements or their corresponding force results are available for post-processing in HyperView only if the .fem file is loaded as a model. 9
- The form argument is only applicable for Frequency Response Analysis. It is ignored in other instances.
- The forms BOTH and COMPLEX do not apply to the .frf output files.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Multiple instances of this card are allowed; if instances are conflicting, the last instance dominates.
- For optimization, the frequency of output to a given format is controlled by the I/O option OUTPUT.
- In general, HyperView does not recognize the SORT2 format for results from the .op2 file. When results are output only in SORT2 format (<Result Keyword> (SORT2, OUTPUT2, ...)), the results are written by OptiStruct into the .op2 file in SORT2 format, but when the .op2 file is imported into HyperView, the results in SORT2 format are not recognized. Therefore, the SORT1 option is recommended for results output in OUTPUT2 format and SORT2 option is recommended for results output in PUNCH format.
- Vector and Tensor plots of some element force results
(weld, beam/bar and gap elements) are available for post-processing in HyperView only if the .fem file is
loaded in the Load model field and the results file is loaded in the Load
results field (Figure 1 is an example illustration of the HyperView
Load model and results panel).Make sure that the Advanced option is selected from the Result Math template: menu.
Figure 1. - For shell elements force results are given as force/unit length.
- format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
- For Fluid velocity output, the Real and Imaginary
parts are calculated as:
(1) vRx=−1ρω∂pI∂x(2) vIx=1ρω∂pR∂xWhere,- ρ
- Fluid density
- p
- Acoustic pressure
- ω
- Frequency
- vRx
- The Real part of the Fluid Velocity along the X-axis
- vIx
- The Imaginary part of the Fluid Velocity along the X-axis
The Fluid Velocities in other directions (Y and Z) can be calculated similarly. Fluid velocity output in Coupled Frequency Response Analysis (Acoustic Analysis) refers to an elemental quantity and not a nodal/grid-based value.
- The HDF5 output is printed to a
.h5 binary results file. The current support of HDF5
output format is:
- In case of Linear Static and Normal
Modes analysis,
- The supported element types for element-based results (in
.h5 format) are:
Result Elements Supported FORCE/ELFORCE CBAR, CBEAM, CONROD, CTRIA3, CTRIA6, CQUAD4, CQUAD8 STRESS CROD, CBAR, CBEAM, CONROD, CELAS1, CELAS2, CBUSH, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CTETRA, CHEXA, CPENTA STRAIN - Corner results are also available for the above results with CQUAD4 and CQUAD8 elements.
.h5 format) are:
- In case of Nonlinear Static
analysis,
- The supported element types for STRESS and
STRAIN results (in .h5
format) are:
Result Elements Supported STRESS, STRAIN
CROD, CELAS1, CBAR, CBEAM, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CHEXA, CPENTA, CTETRA - Corner results are also available for CQUAD4 and CQUAD8.
- DISPLACEMENT, STRESS and STRAIN results are also available on-the-fly during the analysis, if the NLOUT entry is defined in the subcase.
format) are:
- In case of Linear Buckling analysis, only DISPLACEMENT result is available in .h5 format.
Modes analysis,
- Element force statistics are
supported for Direct and Modal Linear Transient Analysis.
Only H3D output is supported for element force statistics and the output is available only for the following elements - CBAR, CBEAM, CELAS1, CELAS2, CONROD, CROD, CBUSH, CVISC, CDAMP1, CDAMP2, CGAP, CWELD, CGAPG and CSEAM.
The following statistics over time are output for Transient Analysis when STATIS or OSTATIS is specified.- Statistics
- Supported Element Force Result Types
- Minimum and Time of Minimum
- X-component, Y-component, Z-component
- Maximum and Time of Maximum
- Magnitude, X-component, Y-component, Z-component
- Absolute Maximum and Time of Absolute Maximum
- Arithmetic Mean, Root Mean Square (RMS), Variance, and Standard Deviation
The Element Force statistics can be viewed in HyperView after loading the H3D file, under Statistics over time option at the end of the timestep list in the Results Browser. Then, various statistics can be chosen from the sub-menu under Element Forces (1D) (Statistics) (s).
