FREQ2
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, final frequency, and the number of logarithmic increments desired.
FREQ2 SID F1 F2 NF
FREQ2 6 1.0 8.0 6
SID Set identification number.
No default (Integer > 0)
F1 First frequency in set.
No default (Real > 0.0)
F2 Last frequency in set.
No default (Real > 0.0, F2 > F1)
NF Number of logarithmic intervals.
Default = 1 (Integer > 0)
  1. FREQ2 entries must be selected with the I/O Options or Subcase Information command FREQUENCY = SID.
  2. The units for F1 and F2 are cycles per unit time.
  3. The frequencies defined by this entry are given by fi = F1*e(i-1)d
    where, d=1NFlnF2F1 and i = 1, 2, ..., (NF + 1).
  4. All FREQi entries with the same set identification numbers will be used. Duplicate frequencies will be ignored. fN and fN1 are considered duplicated if:(1)
    |fNfN1|<DFREQ*|fMAXfMIN|
    Where,
    DFREQ
    User parameter with a default of 10-5 * fMAX
    fMIN
    The maximum and minimum excitation frequencies of the combined FREQi entries
  5. This card is represented as a load collector in HyperMesh.
