HISOUT
I/O Options and Subcase Information Entry The HISOUT command can be used in the I/O Options section to control the amount of data printed to the .hgdata file.
HISOUT = option
Argument | Options | Description |
option | <Integer <
32> Default = 31 |
HISOUT
value is equal to the sum of the desired options:
Example: If design variables and all DRESP2 responses are wanted, enter: HISOUT= 9 |
- When a HISOUT command is not present, a value of 31 is assumed.
